![]() | Home > Puma (Tdci) > Optimal Boost PSI and EGT ranges |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
as a rule of thumb, the EGT should NEVER exceed 750C for longer than a few minutes, else you run the risk of warping the exhaust manifold.
I have the alarm on my EGT monitor set to 650C, and I rarely touch that limit. I run the BAS remap, and I drive my Puma like I stole it ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
redline Member Since: 28 Jun 2015 Location: Mountains and Lakes Posts: 221 ![]() ![]() |
I also have my alarm set at 650degC, and rarely reach it.
1,000degC ... ![]() |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 389 ![]() ![]() ![]() |
gents, the gauge is in Fahrenheit....
So only 537.778 degrees c - you need to be trying harder 😊
did you buy it in the 18th century? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Lmao! Well it's what the eBay man sent me mate!
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
hi Naks just wondering what brand of guage you used and were did you put the probe cheers Tim ![]() |
