Home > Puma (Tdci) > Optimal Boost PSI and EGT ranges
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Im curious what the 2.2 Puma engine is rated for. What should the boost PSI be? and what about the optimal Exhaust Gas Temp?
I am running the Allisport 150hp tune. Today with new pyrometer I was getting 1,000 degrees on the freeway. In low gears my boost PSI was up over 25. Just wondering what is normal, and more importantly what is dangerous for EGT. Thanks
Post #581496 30th Nov 2016 3:08am
Naks
as a rule of thumb, the EGT should NEVER exceed 750C for longer than a few minutes, else you run the risk of warping the exhaust manifold.
I have the alarm on my EGT monitor set to 650C, and I rarely touch that limit. I run the BAS remap, and I drive my Puma like I stole it Thumbs Up --
Post #581507 30th Nov 2016 8:27am
redline
Switzerland
I also have my alarm set at 650degC, and rarely reach it.
1,000degC ... Shocked ... your EGT gauge is likely not properly calibrated. If that were a true reading, you'd quickly have some quite evident problems!!
Post #585063 14th Dec 2016 6:23pm
big110
gents, the gauge is in Fahrenheit....
Post #585186 14th Dec 2016 11:38pm
So only 537.778 degrees c - you need to be trying harder 😊
Post #585242 15th Dec 2016 8:02am
Naks
did you buy it in the 18th century? Rolling with laughter --
Post #585247 15th Dec 2016 8:33am
big110
Lmao! Well it's what the eBay man sent me mate!
Post #585372 15th Dec 2016 7:42pm
Tim seymour
Australia
hi Naks just wondering what brand of guage you used and were did you put the probe cheers Tim Razz Cess the Taswegian
Post #628639 3rd Jun 2017 9:49am
