![]() | Home > Puma (Tdci) > Brand new Puma drifting to the left |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Good luck!
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
First quick drive in peak traffic from the stealer to work, looks like it pulls to the left even more now. More thorough testing on the way home on open roads at 100kmh. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Good news - the steering is much sharper now with the new steering box.
Bad news - it pulls to the left even more. Am going to have the wheel alignment done this morning, maybe have my indie mechanic re-centre the steering box during the week. If that does not help, will have a shim done on the left front radius arm to correct the 0.4 deg difference in caster angle. after that I dunno... ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
You are drifting and I'm wobbling.I have steering feedback on some rutted roads.Have put up a post for help and working on it today. Puma 110 SW
90 V8 SOFT TOP |
Ok, I spoke to the guys at 5th Avenue Motors who do the suspension work for LR Stellenbosch. They found a 20mm difference between the left and right wheelbase
![]() Landy will be going back to them to see if they can sort this out... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
Good luck with your issues, personally I would have taken it back and demanded a new one by now... 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
the chssis is out of alignment.
get a new chassis fitted by LR, a galvy one! |
The chassis is fine, that was the first thing they checked just after I got the vehicle. I suspect the radius arm mount on the front left was incorrectly welded/tightened. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
is that not part of the chassis then? your money mate, you got a dud, not me! |
Chaps,
Landy went back to LR CL yesterday who sent it to 5th Avenue Motors again. I just spoke to the technician who is working on my landy and this is what he said: - Wheelbase difference of 10-15mm on the left compared to the right. They do not see many of these n Defenders but manage to fix 90% of them with a slight residual 'normal' pull due to road camber. - They can fix it by re-positioning the wheel, but it will look 'out of position' when compared to the right. However according to him this will not affect wheel travel and is only cosmetic. They are waiting for feedback from LRCL & LRSA before any repairs are done. Hopefully this time it will be fixed. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Amazed you are keeping so up beat and level headed about it.
I would be demanding a replacement car........if you sell the car on at some point in the future and someone picks up the visual difference in where the wheel sits in the arch they are likely to suspect accident damage and poor repair, you are then leading to a conversation about what has happened. By doing a bodge fix you are saving them the aggravation and potential loss of a car. Ultimately if you are happy then you are happy but I would be thinking very hard. |
Well, it's been a year now so I would lose money on it and would not recoup all of the accessories I fitted. Besides, if I get a replacement, who's to say it won't be an even worse lemon? At least with this one I know what's wrong ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Further measurements by the specialist revealed that the rear axle was at fault, with a 0.3deg thrust angle. Basically the rear axle was pointing right, thus making the front pivot to the left. This was fixed by repositioning the rear axle to make it parallel to the front axle.
Got the landy back this afternoon. On the drive back home I noticed the following: on a good flat road the landy goes straight, but as soon as the road is slightly cambered or uneven, it swings to the left quite badly. I'm at my wits end here, not sure what the next step is... any advice? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bored of this now Naks, the chassis has been built well out of kilter, 10-15mm! Sell it and buy a toyota ASAP |
