![]() | Home > Technical > Leaking vacuum pump gasket - Puma 2009 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
I would change both, and I don't remember it being at all difficult.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
Many just replace the gasket, or you could change both as suggested above.
IIRC, the coupling is a pain in the backside to remove on the pipe. Removal other than that is easy, and easy access, replace fixings and torque to WSM specs. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 593 ![]() ![]() ![]() |
Parts ordered, thanks!
![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
it may be the single seal behind the pulley on the vacuum pump itself - new one is modified and has a double seal
Mark |
Seal failure tends to blow oil all over the engine bay and is fairly unmistakable.
Yes, it's what I thought, it's not the case here, just a small-ish oil leak underneath the vacuum pump.
Nevertheless I ordered a new pump, gasket and ancillary belt, while at it... βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
By undoing the brass nut (in yellow) below? Or how...
![]() I removed the old pump by undoing the brass nut to disconnect the vacuum pipe, but then there is a new brass nut already in place on the new pump, so I am not sure I did right... Should I just remove the new one and refit the old brass nut connected to the vacuum pipe? βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
The nut stays in place. You fiddle about with the collar that is round the pipe where it emerges from the nut, and after a while the pipe miraculously comes free, even though you're not really sure what you did.
At least that is how it was for me. |
Blackwolf, brilliant, as usual
![]() You help on this forum is truly invaluable, many thanks!! ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
