Home > Technical > Leaking vacuum pump gasket - Puma 2009
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all,
I have an oil leak next to the brake vacuum pump on my MY09 Puma 2.4.
I know this is a very common fault, but it looks like it's the gasket underneath the pump which is leaking, doesn't look like the pump itself is faulty.
What do you reckon, should I:
- Replace the gasket only, or
- Replace the pump and the gasket, or
- Replace the pump, the gasket, and the ancillary/fan belt as well
Considering this is the original vacuum pump and belt, and the car is 7 years old with less than 60 thou miles on the clock...
Last question, is it a difficult task? Can this be done by a single person alone?
Cheers! β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #584679 13th Dec 2016 9:07am
I would change both, and I don't remember it being at all difficult.
Post #584692 13th Dec 2016 10:08am
Many just replace the gasket, or you could change both as suggested above.
IIRC, the coupling is a pain in the backside to remove on the pipe.
Removal other than that is easy, and easy access, replace fixings and torque to WSM specs. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #584703 13th Dec 2016 11:19am
o4dn
Parts ordered, thanks! Thumbs Up β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #584771 13th Dec 2016 3:50pm
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
it may be the single seal behind the pulley on the vacuum pump itself - new one is modified and has a double seal
Mark
Post #584776 13th Dec 2016 4:40pm
Seal failure tends to blow oil all over the engine bay and is fairly unmistakable.
Post #584783 13th Dec 2016 5:00pm
o4dn
Yes, it's what I thought, it's not the case here, just a small-ish oil leak underneath the vacuum pump.
Nevertheless I ordered a new pump, gasket and ancillary belt, while at it... β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #584785 13th Dec 2016 5:04pm
o4dn
How to disconnect the brake vacuum pipe?
By undoing the brass nut (in yellow) below? Or how...
I removed the old pump by undoing the brass nut to disconnect the vacuum pipe, but then there is a new brass nut already in place on the new pump, so I am not sure I did right...
Should I just remove the new one and refit the old brass nut connected to the vacuum pipe? β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #586806 21st Dec 2016 7:10pm
The nut stays in place. You fiddle about with the collar that is round the pipe where it emerges from the nut, and after a while the pipe miraculously comes free, even though you're not really sure what you did.
At least that is how it was for me.
Post #586813 21st Dec 2016 7:41pm
o4dn
Blackwolf, brilliant, as usual Bow down
You help on this forum is truly invaluable, many thanks!! Thumbs Up β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #586817 21st Dec 2016 7:49pm
