Home > Maintenance & Modifications > Knackered brakes
Squirdan
2010 Defender 90 Puma 2.4 XS CSW Keswick Green
Knackered brakes
Had my 55 reg 110 in for service and general check up this week
Garage tell me the brakes need replacing, not just discs and pads but that the calliper are shot
I did notice it pulled to the left a bit on high speed braking
47k miles / 10 years old so seems plausible just a larger bill than I hoped
Likely to need doing or them pulling a fast one?? Cheers
Post #583680 9th Dec 2016 1:27pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If the pistons on the callipers are heavily pitted then most garages will rather replace the unit than split a calliper to replace the pistons. I would ask what is wrong with the callipers and why they recommend replacement. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #583685 9th Dec 2016 1:53pm
It is highly plausible that a 10-year-old vehicle has sticking pistons in the calipers, and the garage solution to this is to replace the calipers (it is cheaper in parts and labour usually to do this, and there is a more predictable outcome, than to overhaul the old calipers with new pistons. The latter is more labour-intensive though possibly cheaper on parts, and makes some sense cfor DIY).
Post #583686 9th Dec 2016 1:54pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I've replaced quite a few on Defenders, certainly more than vans and cars!
2 fronts replaced on a 2011 were the most recent.
Replacing the seals and pistons are hardly worth the bother now,
You can get refurb Pagid calipers for £70 a side.
My 2008 could do with a pair upfront soon.... Rolling Eyes 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #583690 9th Dec 2016 2:00pm
Stacey007
I Had one around 6 months ago as it was pulling to the left I think the part was around £60 plus fitting.
Is there anything better to fit without going down the silly expense route?
Larger discs . better pads?
Would they fit / be any better
Just asking as if I do the Remap and extra bits the brake do feel a bit lame compared to other cars I have had...
Post #583704 9th Dec 2016 3:30pm
Squirdan
thanks for replies
thats exactly it - corrosion and sticking pistons
I have looked into upgrades but v little thats sensible for less than £3k AP or Alcon stuff and most of the upgrades require bigger wheels than my std 16 inch boosts
have given the go ahead for AP / Lockheed branded calipers, c. £100 each, exact same as LR OEM just not in a LR box..
orig quote from garage was part no. SEB500460 at £466 + vat each Shocked Shocked
Post #583713 9th Dec 2016 4:17pm
geobloke
Sticking pitted Pistons... The plague of defender brakes...
Best replace with recon'd standard items and if you do want a small upgrade then drilled and grooved discs and EBC green stuff pads are a great option.
Brakes on my 110 are superb with this setup. Just remember to bed it all in properly once fitted.
Post #583714 9th Dec 2016 4:27pm
Good choice.
Post #583715 9th Dec 2016 4:28pm
Morepower
New Zealand
Just replaced both my rear calipers as they where showing signs of drag... did the disks and pads/pins etc at the same time....
2013my 110 with 31K on the clock... So you've done quite well!!!
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #583739 9th Dec 2016 6:31pm
LR90XS2011
unfortunate thing with defender calipers is the 70s design that does not protect the pistons from the elements like later designs tend to, this along with chromed steel pistons will unfortunately result in a more frequent replacement requirement than more modern designs. Having said that they are comparatively reasonably priced, and if you are so inclined you can fit stainless pistons DEFENDER 90 TDCI XS,
Post #583750 9th Dec 2016 7:23pm
