Home > My Defender > Grafty's Td5 90
Page 2 of 124 <123 ... 122123124>
grafty99
Yes L90DNY,
Engine wise;
Hybrid variable geometry turbo by turbo technics.
Allisport intercooler (full size).
Black silicone hoses.
100mm airbox feed with water separator removed.
EGR delete.
Decat down pipe
3 inch exhaust with rear exit.
Injector plunger gaps set (made quite a difference to mine).
Dual channel anti limit box (MAP and MAF).
Matched engine calibration by IRB developments.
Drive train and brake wise;
Goodridge stainless brake hoses.
110 vented brakes front and solid rear with the larger 110 rear calipers and discs.
Full superpro bushes.
24.5mm rear anti roll bar with custom solid mounts.
-2 inch 3 stage progressive suspension with Bilstien dampers all round.
30mm solid steering and track bar from Gwyn Lewis.
HD R380 gearbox with uprated bearings and the 5th gear out of a disco 2 V8 for quieter motorway cruise.
Q cut HD LT230 transfer box with 1.22 gearing and an Ashcroft ATB centre diff.
Also a slick shift which if I am honest I'm not overly impressed with. However it is on a new gearbox so may well free up with time Very Happy
Yet to fit;
A big brake kit coming from IRB, 6pot vented fronts and 4pot rears Twisted Evil
ATB diffs front and rear.
And exhaust as mentioned.
All of the above give a car like ride quality and handling on road whilst still being flexible enough off road.
The gearing gives 33 ish mph per 1000 rpm so 80mph is around 2350 rpm.
Around where I live in average about 32mpg on a run about 28 but I tend to sit at 80 on the motorway.
Hope that helps Thumbs Up
Post #580808 27th Nov 2016 6:11pm
Like it! You must be the same age as me give or take. Thumbs Up
What paint colour did you go for? Looks like a different shade and tone and definitely metallic. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #580819 27th Nov 2016 7:09pm
grafty99
Thank you Steve, I guess so? I'm 24 at the moment - 25 in March.
The colour belive it or not is original, bog standard Caledonian Blue non metallic. The farmers choice of the noughties! It is a nice colour when polished though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #580825 27th Nov 2016 7:23pm
grafty99
Where abouts in the South West are you? Maybe we should meet up some time! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #580826 27th Nov 2016 7:25pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Wow a lot then! Really interesting as I've just finished/finishing my td5 re build and the performance stuff is next on the list!
I'd be keen for a meet up also, I'm in Somerset and 25 Thumbs Up
Post #580848 27th Nov 2016 8:20pm
grafty99
That sounds good Thumbs Up How about next weekend? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #580866 27th Nov 2016 8:38pm
L110CDL
Thanks for the reply grafty99, note to myself, that i must remember not to try and burn you off at the lights in the future Rolling with laughter Clayton.
Keeper.
Post #580881 27th Nov 2016 8:49pm
L90DNY
Rolling with laughter not wise looking at that list !
Grafty99 I'll PM you!
Post #580888 27th Nov 2016 9:04pm
L110CDL
^ ^ ^ Not wise as you said Big Cry But would be good fun all the same Whistle Clayton.
Keeper.
Post #580904 27th Nov 2016 9:38pm
grafty99
We should arrange a Devon defender2 meet! As long as there are no traffic lights around! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #580921 27th Nov 2016 10:08pm
L110CDL
^ ^ ^ Rolling with laughter
Sounds good to me grafty99 , up for that Thumbs Up Clayton.
Keeper.
Post #580979 27th Nov 2016 11:41pm
grafty99
Quick update on the Range Rover classic stalks, I can't find the pictures I took whilst I was doing it but basically;
Carefully cut the hazard switch off leaving the clip for the switch holder. Once removed make sure non of the brass contact strips inside are touching.
Then there is some work required to get the range rover switch holders to fit the defender column but I can't find any pictures of that part on Google.
When they are mounted then you have to slightly enlarge the switch apertures on the defender plastic shroud as the stalks are chunkier so need more room to move.
I had to do some final trimming on the stalks themselves for the last bit of movement in this area;
That is the best I can do with Google images. I will take some pictures later of the finished article in the daylight Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #581037 28th Nov 2016 10:31am
grafty99
Ordered a genuine rev counter off Dan at Duckworth landrover yesterday. Looking forward to fitting that this week Mr. Green 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #581391 29th Nov 2016 8:17pm
Stiff1
That's great insight into the stalk fitting.
Re the wiring, having never removed the stalks, do the existing connectors just fit the new stalk and into the same pin numbers?
Also, what is the black wire pictured for?
Thanks
Post #581395 29th Nov 2016 8:22pm
grafty99
The large black cable is the fiber optic strands for the illumination. I shrink wrapped a green led onto the end of each one for side for the illumination.
As for the wiring I think that the defender loom plugs into the range rover stalks for the most part but to be honest I can't fully remember Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #581475 30th Nov 2016 12:15am
