Home > Maintenance & Modifications > If you got a 110 with mudflaps, they will fall off -do this!
Tiger
Not if...
when..
Very cheap simple fix that is better done before they break through the rear panel alloy and you lose them on the M56
Small bit of angle alloy (not steel)
Drill hole
Place above mudflap bracket fixing to spread the load and beef up the fixing point
Job done! Thumbs Up
How it sits inside the panel
This is what 6mm hole looks like
Bolt it all up
Prevent this Big Cry (yep that the bit of the panel the mudflap was hanging off)
Post #580343 25th Nov 2016 11:08am
Stacey007
Did almost the exact same thing last weekend as mine pulled through....oooh
Thumbs Up
Post #580346 25th Nov 2016 11:21am
mk1collector
Did exactly the same a year or two ago when my mudflap broke through the panel Ray
My build thread
Post #580362 25th Nov 2016 12:42pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Ditto!
Post #580364 25th Nov 2016 12:44pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Same here.
B&Q sell the angled alloy if you do not have access to a wholesale source. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #580367 25th Nov 2016 1:01pm
miket
I've done the same repair using a parts supplied by 4x4 Overlander (http://www.4x4overlander.com/product/110-mudflap-reinforcing-bracket-rear/).
Nice tidy repair.
Mike
Post #580370 25th Nov 2016 1:07pm
ericvv
There are long existing cleaner tailor made solutions you can do before it becomes a problem. Those with a 110, better install these from new, otherwise you are guaranteed to get this damage to your truck.
This simple solution was initially designed by Entreq, but now available from various suppliers.
Eric
http://www.entreq.de/karosserie-und-chassi...r-110.html
http://www.4x4overlander.com/product/110-m...cket-rear/ You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #580373 25th Nov 2016 1:11pm
Retroanaconda
£33 for a bit of aluminium and some bolts!
Just get a cheap section of alu angle as described above that will do the same job. £8 for an 8' length of 1/2" x 1/2" angle at Wickes - that'd do a few 110s!
Post #580375 25th Nov 2016 1:20pm
mk1collector
Just to add, if you isolate the bolt and mud flap bracket from the body with nylon washers you don't get and metal corrosion between the steel and ally. Ray
My build thread
Post #580389 25th Nov 2016 1:52pm
JOW240725
Thanks for the heads up, I'll add it to the list. Thumbs Up James
Instagram @suffolk_rovers
Post #580397 25th Nov 2016 2:08pm
Cupboard
Another, better option (though a bit more expensive) is the Gwyn Lewis kit.
Post #580403 25th Nov 2016 2:29pm
Thon
^^^^^^ Agreed^^^^^^
Tucks the mudflap up a little tighter too, plus it has a quick release mechanism should you need to get them off for some extreme mudding. It has a stiffener/strengthener bar that is bolted to the lower flange of the wing to spread the load better.
http://www.gwynlewis4x4.co.uk/product/defe...epped-tub/
Post #580421 25th Nov 2016 4:09pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Another vote for aluminium. I used a length of green house 90° angle aluminium on the old 110, held in place with pop rivets, ran it along the whole length of the fold at the bottom of the wing. Seemed pretty robust afterwards. Used a bit of margarine tub to isolate from the mudflap bracket steel.
The Gywn Lewis kit should protect the fuel pipes on the 110 too. I should know, except that my kit is still on the bench awaiting fitment Embarassed Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #580475 25th Nov 2016 7:54pm
Welshsurferdude
Wales
bit late for me in my scenario, both of mine are long gone after 145k lol. 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #580492 25th Nov 2016 8:45pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
I have carried out a similar modification on my 110. I realised with my first 2007 110 that the heavy mudflap would flex on he body mount and eventually crack the metal. I modified that 110 and have done the same on my 2013 Defender.
I placed aluminium strip on the inside lip of the panel and also ran an aluminium flat strip secured with outdoor rated double sided tape on the lower side of the lip for the whole length. Not only does it stop the flexing, I didn't have to drill any additional holes in the panel, only cost a few dollars, and will protect the exposed edge of the panel from stone damage.
Using double sided tape might not be suitable where salt on roads might get trapped, but luckily I don't have to worry about that living in Australia.
Post #580536 26th Nov 2016 2:08am
