Home > Maintenance & Modifications > LED worklights
SkyFallSilver
Kuwait
LED worklights
Hello,
Camping season is here and I was wondering if it is possible to install 2 work lamps on the roof rack and not running it to the battery but on something that uses solar energy if there is such a thing ? 2016 Defender 90 Adventure Edition
Post #580049 24th Nov 2016 9:42am
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
you would neded a battery to store the solar power on the roof rack as you wont want the lights on when the sun is out I suspect.
tc
Post #580053 24th Nov 2016 9:50am
SkyFallSilver
Kuwait
Im running 4 roof rack led lamps on the battery and 2 led lights on the front bumper as well.
Don't want to drain the battery. 2016 Defender 90 Adventure Edition
Post #580054 24th Nov 2016 9:52am
Cupboard
Simplest thing would probably to put a second battery alongside the current one.
Or you can get portable, rechargeable worklights.
How much light do you need, how long do you need the light for and how often are you going to be moving? Something like the Labcraft scenelights only draw about 1.2A so you could have one of them running for a few hours and should be fine on the starter battery (unless the battery is knackered anyway).
Post #580060 24th Nov 2016 10:08am
SkyFallSilver
Kuwait
Can portable work lights be mounted on the roof rack ?
I like that idea and any suggestions. 2016 Defender 90 Adventure Edition
Post #580069 24th Nov 2016 10:37am
