Home > Off Topic > Dry ice / soda blasting painted beams?
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I know a few forum members have restored timber framed houses,
So I'm wondering if anyone has had any oak beams blasted clean?
I've seen them being shot blasted, but didn't like the damage caused to surrounding plaster work.
Has anyone used, or know of anyone who's had them soda/ dry ice blasted?
I've got a few names and numbers to call, but wouldn't mind a recommendation too.
The work would be carried out in Berkshire.
Cheers 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #579065 19th Nov 2016 9:34pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Worth trying to talk with a regional architect with the National Trust or English Heritage, they would have a list of folk who shouldn't do too much damage. We had a local company do our beams in our cottage, meant to have had lots of recommendations on their website but they damaged a ton of plaster, plus the dust was incredible, stick a mask on and carefully keep an eye on them. Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #579098 19th Nov 2016 11:32pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I was involved with dry ice blasting in Japan when I worked out there. It's a very clean process and would do little damage I feel. It was quite expensive if I remember correctly but that was probably because it was Japan and quite new at the time.
Post #579104 20th Nov 2016 12:07am
bob neville
We were going to have the beams in our last house blasted but the builders did nor recommend it. On their advice we got the conservation officer in for advice. He told us that the beams would probably take the blasting but there may have been weak areas that would be destroyed if the operator did not take extreme care.
As an alternative he suggested trying Peelaway -
http://www.wood-finishes-direct.com/product/peelaway-one
If worked well but is a messy and time consuming job but the end result was excellent.
2013 Defender 90 CSW - sold
Post #579150 20th Nov 2016 11:37am
justinp
The peelaway 21 paint stripper is great for stripping doors, but it can darken hardwood beams. I now use nitromoors with good results.
What ever you use you need care and patience, as just under the thin crust of the beam, may be a fragile wood worm eaten dusty sponge like wood.
Post #579171 20th Nov 2016 1:32pm
justinp
Here's a photo of some beams I recently stripped using nitromoors.
Post #579172 20th Nov 2016 1:35pm
bob neville
Nitromors didn't work on ours as the paint was so thick and rock hard !
I have heard that Peelaway may darken hardwood but as ours were black to start with anything was lighter !!
Good result on those beams though Thumbs Up
Post #579174 20th Nov 2016 1:36pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Hi Ian,
Have a chat with Robthrutheblock on the LRSOC Forum as he has used Dry ice blasting extensively on various projects and was a mobile service!
Andy Wink Working towards Carry on camping!
Post #579177 20th Nov 2016 2:01pm
ian series 1
Thanks very much for your feedback chaps,
I will do some research in the week, and try a find out a bit more about the process.
I know one thing, it's going to get messy! Neutral
Sadly I'm not sure about the Nitromorse? There is just way too many to make it an option.
And I don't think I would have the time to be honest.
I will give Julian a shout Andy, I've been meaning to talk to him for a while.
Cheers guys Thumbs Up 80" 80" 86" 88" 90"
Post #579207 20th Nov 2016 5:24pm
Romadog
Post #579212 20th Nov 2016 6:02pm
ian series 1
Cheers Romadog Thumbs Up
I did find Heritage last night, going to ring them in the morning. 80" 80" 86" 88" 90"
Post #579225 20th Nov 2016 6:53pm
defender9
Dry ice blasting is the least messy of all the blasting processes as the blast media (frozen CO2) sublimes into the atmosphere and essentially disappears. You have to be careful using it in confined areas because it could deplete oxygen but should be ok for blasting beams as long as they are not fragile but that applies with a lot of blasting processes.
Post #579244 20th Nov 2016 7:39pm
