![]() | Home > Off Topic > Dry ice / soda blasting painted beams? |
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1043 ![]() ![]() ![]() |
Worth trying to talk with a regional architect with the National Trust or English Heritage, they would have a list of folk who shouldn't do too much damage. We had a local company do our beams in our cottage, meant to have had lots of recommendations on their website but they damaged a ton of plaster, plus the dust was incredible, stick a mask on and carefully keep an eye on them. Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
I was involved with dry ice blasting in Japan when I worked out there. It's a very clean process and would do little damage I feel. It was quite expensive if I remember correctly but that was probably because it was Japan and quite new at the time.
We were going to have the beams in our last house blasted but the builders did nor recommend it. On their advice we got the conservation officer in for advice. He told us that the beams would probably take the blasting but there may have been weak areas that would be destroyed if the operator did not take extreme care.
As an alternative he suggested trying Peelaway - http://www.wood-finishes-direct.com/product/peelaway-one If worked well but is a messy and time consuming job but the end result was excellent. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
justinp Member Since: 24 Jun 2016 Location: Cambridge Posts: 167 ![]() ![]() |
The peelaway 21 paint stripper is great for stripping doors, but it can darken hardwood beams. I now use nitromoors with good results.
What ever you use you need care and patience, as just under the thin crust of the beam, may be a fragile wood worm eaten dusty sponge like wood. |
Here's a photo of some beams I recently stripped using nitromoors.
Nitromors didn't work on ours as the paint was so thick and rock hard !
I have heard that Peelaway may darken hardwood but as ours were black to start with anything was lighter !! Good result on those beams though ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492 ![]() ![]() ![]() |
Hi Ian,
Have a chat with Robthrutheblock on the LRSOC Forum as he has used Dry ice blasting extensively on various projects and was a mobile service! Andy ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Thanks very much for your feedback chaps,
I will do some research in the week, and try a find out a bit more about the process. I know one thing, it's going to get messy! ![]() Sadly I'm not sure about the Nitromorse? There is just way too many to make it an option. And I don't think I would have the time to be honest. I will give Julian a shout Andy, I've been meaning to talk to him for a while. Cheers guys ![]() Wanted, Forward Control Anything considered. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
http://www.cryogenesis.co.uk/
http://www.heritagedryiceblasting.co.uk/ http://www.heritagedryiceblasting.co.uk/hampshire-project/ Get any left over Series parts cleaned too ! ![]() |
Cheers Romadog
![]() I did find Heritage last night, going to ring them in the morning. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Dry ice blasting is the least messy of all the blasting processes as the blast media (frozen CO2) sublimes into the atmosphere and essentially disappears. You have to be careful using it in confined areas because it could deplete oxygen but should be ok for blasting beams as long as they are not fragile but that applies with a lot of blasting processes.
