![]() | Home > Maintenance & Modifications > That "oh cr#p" moment... |
| JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706
I would give it a large dose of WD40 over night and drill the centre out. Insert a stud extractor and it should come out.
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Done exactly the same today.
As you said just drill carefully gradually increasing drill size. Use hammer and punch to crush bolt inwards - just to break seal with captive nut. Then use mole grips to slowly unwind. Copious amounts of WD-40 required throughout the process. |
| blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92
Ah, feels a little better knowing I'm not the only one that's done it...
Just ordered a stud extracting kit on Amazon - don't you just love prime, delivered tomorrow (hopefully early enough that I can get it done tomorrow). |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Another good way to remove a headless bolt.
Left handed drill bit, drill in the centre the gentle heat from the drill helps crack it off and the anti-clockwise rotation helps unwind the bolt Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
| All times are GMT |
