Home > Td5 > My defender has just been sick in the office car park
Motoberg
Oh dear, a 2 foot yellowy liquid puddle has evolved on the floor under the engine.
Checked the expansion tank which needed water but by no means empty.
If something had parted surely it would empty the entire contents of the cooling system on the floor ?
weird ?
Post #577911 15th Nov 2016 4:26pm
xcentric
sounds more like urine than vomit to me
Post #577914 15th Nov 2016 4:40pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Did you check your brake fluid?? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #577915 15th Nov 2016 4:41pm
Motoberg
good point Shocked
Post #577916 15th Nov 2016 4:47pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Where exactly is it? Mine had a vomit at work at the start of the year, it was the flexible brake pipe connector that had leaked due to rust, the one going from chassis to axle.. this happened 2 weeks after an MOT and full inspection ...
Lucky I spotted it Neutral
Post #578027 15th Nov 2016 10:02pm
Motoberg
No idea, need to get it in bits at the weekend to find out, of course the MOT is due on Monday Rolling with laughter
Post #578210 16th Nov 2016 4:52pm
shaggydog
Are you sure it wasn't there when you parked and you didn't notice?
Speaking from experience, err, a friend had Laughing Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #578432 17th Nov 2016 1:43pm
Motoberg
unfortunately not, we have numbered spaces at the office so my bus is the only thing that parks there Sad
Post #578474 17th Nov 2016 4:55pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Happened to me some years ago with a Range Rover Classic that had been stood for 12 hours, a great puddle of reddish liquid had appeared under the engine . Had a quick look round but didn't dare move it so walking home at 03.00 am after wasting an hour in the pouring rain. Next day called out a recovery to take it to the dealers who spent 4 days searching and swapping parts out just in case ( Oh yes and running up a bill) they couldn't find anything, it was a good job I have a warranty from them. A week later the security team came back to working with my shift and one of them tells me in passing how he dropped a raspberry frozen lolly on the floor of the car park the last shift he worked with me and had kicked it under a car so nobody would step in the remains. Oh how we laughed .
I laughed last when I sent him the bill for Taxi's and a mocked up bill from the dealers in total £2500.00. Rolling with laughter Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #578478 17th Nov 2016 5:14pm
dorsetsmith
had coolant leak on 2003 td5 left hand side for engine small amount would run down to ledge at bottom engine block only leak then engine cold, it tuned out to be 1nich plug in between exhaust ports on the head 3 hr fix 3 gasket and 13mm nuts
heater matrix top end seal leaking it would drain down coolant expansion tank to the same level and heater out put cold new heater matrix old stock MOD part 1997 raped in brown paper and brown box too, sorted still good to day Thumbs Up
also early type fuel cooler can leak too driver side engine round tube about 5 inches long the O ring perish at ether end
Post #578486 17th Nov 2016 6:01pm
V8GPC
a friend of mine had his engine out twice trying to sort a rear crank seal leak; he thought he had sorted it until the next morning when there was a large pool of oil under his bell housing... what he didn't know is one of us poured it there on the way back from the pub... how we laughed when he thought the engine had to come out again. Rolling with laughter
Post #578610 18th Nov 2016 8:14am
grafty99
Looking at your avatar it looks like your vehicle has aircon. The gas contains a yellow/green liquid that is there to highlight leaks and show up in the event of a crash. Check that your aircon is working too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #578621 18th Nov 2016 9:38am
Motoberg
I'm impressed you can tell it has aircon from my avatar !! Is green stuff leaking out in the photo too ? Laughing
The aircon compressor was removed for some reason by the previous owner so it has an 'pipes open to atmosphere' system Shocked
Post #578662 18th Nov 2016 12:10pm
Motoberg
2 bolt union under the power steering pump had come slightly loose.
Luckily it was an easy fix !
Thumbs Up
Post #578980 19th Nov 2016 5:39pm
