![]() | Home > Puma (Tdci) > Heavy oil use |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17941 ![]() ![]() ![]() |
If it's losing oil, it's either leaking out or being burnt. I imagine you'd notice a leak, so burning is more likely. Turbo seals failing would do it, since the oil pumped into the turbo bearings will leak into the induction system and be burnt, and is perhaps the most likely cause. On a 2008 you are in the at risk period for the dreaded PCJ (piston cooling jet) problem which resulted in serious bore wear and could also be a cause for heavy oil consumption.
The whistling noise could be turbo/intercooler hoses, or the exhaust manifold to head, or manifold to turbo gaskets. |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
What trip-range do you drive? It often is caused due to short trips, motor is not getting warm. Another point will be viskosity of the oil you use. 0w- or 5w- can make a difference.
I would not overstate a higher consumption. |
LRnovice Member Since: 08 May 2008 Location: Cardiff Posts: 64 ![]() ![]() |
Thanks for the advice. Im hoping its not the PCJ problem as a new engine will be expensive I imagine.
Hellz Member Since: 17 Nov 2016 Location: Bristol Posts: 1 ![]() |
My tdci 2010 was using around the same 1lt to 1000miles no smoke . It has done around 50.000 miles got it when it was on 47.000 miles. So not sure how long it had been using so much. Was a cheap easy fix turned out to be the copper washers on bottom end of the injectors all 4 letting buy. Done 2000 miles since and not a drop of oil used.
snowric Member Since: 01 Aug 2011 Location: London Posts: 20 ![]() ![]() ![]() |
my 2009 tdci was using this and then epic amounts. Turned out that the rocker cover was not properly sealed, that the oil filter was not properly attached and the sump was leaking. What was weird was that there was not tons of oil lying around the front yard/ drive.
There was oil on the side of the engine where the rocker cover was leaking; oil all round the filter housing and a bit of oil around the sump. But these have all been dealt with and now I use next to no oil 63k Puma. I too get a little smoke on start up. Snowy |
I belive it solved your problem. But how does oil consumption and badly seated/sealed injectors correspond? Is it due to the loss of compression that oil is able to get along the piston rings into the chamber where it is burnt? Or is there another explanation? |
