Home > Maintenance & Modifications > Soundproofing/de-resonance/insulating the roof
Page 2 of 2 <12
mk1collector
Your probably right, no point in doing the biggest flattest panel on the vehicle that happens to be very close to your ears Rolling with laughter Ray
My build thread
Post #577112 11th Nov 2016 2:14pm
mse
In short yes
The road, transmission and engine noise isnt above you though - just some, maybe wind noise and rain??
No other car ive come across has the roof plastered in sound proofing, i cant talk about the latest range rover, but it doesnt, nor did my sport, the disco, evoque etc
Like i say, we have the premium headlining which is thinker than the standard, which i suspect also makes a difference - as in most cars...but i do think, after the time and expense, its probably only neglagably quieter more likely a placebo (like when you service a car if feels better!)
When i soundproofed the rear of the 110, i didnt subscribe to the "plaster sound proofing everywhere" school of thought - i left the front with standard sound proofing, the roof un touched, inserted side panels for the van section and did the majority (but not all) of the floor and tub from front seats backward.
I stand by i wouldn't waste time doing the roof, certainly with the headlining described and you dont need to do all of every panel to get a positive impact. I only did the rear of the tub because i had mateial left over
I wouldnt even waste time taking the door panels off - but would do that first over the roof any day Mike
Post #577118 11th Nov 2016 2:28pm
Stacey007
^ Biggest difference in mine I noticed was the Seat box's and inside them.
The the doors, as they sound more solid when you close them.
Interesting if I leave the roof, little difference?
With what I have done it does make a difference up to 40mph easy. At motorway 60mph plus hard to tell as easy?
Maybe rather than the roof I should try something under the bonnet.
Post #577125 11th Nov 2016 3:08pm
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
I can only speak of the evoque, but this has a large deadener pad fitted to the roof, also most panels in the car have a section of anti-resonation material sprayed onto them to reduce drum. As has been mentioned, it doesn't need to be full coverage, a patch in the centre will sort it mostly, then foam can do the rest! One word of possible caution, I had issue with tracker signal and the use of butile/foil insulation in the front of my 90 cab, resulting in me taking off a lot of the insulation, not a fun job! Obviously there is an issue with the signal reflecting off the foil?
Cheers,
Lewis
Post #577126 11th Nov 2016 3:08pm
mse
Yes the rubber pad (used to be on the defender doors i last owned) are there on many many cars, stops the panel vibration/rattle/tinny noise - but isnt sound proofing -the front section of the defender roof would probably lend itself to that more than the rear.
Of course, all the land rovers with a panoramic roof, you wont see that either - i didnt think our evoque coupe had anything in the roof, but im not going to remove the headlining to check...ill have to look next time im around one!
But like i say soundproofing and panel resonance are different Mike
Post #577127 11th Nov 2016 3:26pm
mse
duplicate Mike
Post #577131 11th Nov 2016 3:33pm
Lew-M
Yeh I wouldn't go pulling the headliner down, they like to crease if you even look at them wrong Laughing as well as the deadener pad, later models actually have a small mass damper fitted to the rear of the roof also. Like you say though this is all focused on resonance, there is little to no traditional sound insulation in the car, it's mostly focused around the trim parts, of which our defenders have a lack of in comparison!
Cheers,
Lew
Post #577138 11th Nov 2016 4:06pm
Grenadier
Cheers,
Lewis
Must say, this is something I considered. Not whether I'd put any SC on the roof panels, but why (when you watch the SC demo video ) you'd bother doing the whole roof. The piece in the video cannot account for more than 20% of the panel coverage, so why plaster the whole roof in the stuff? My own counter arguement is that with the foil backing there must be some Cold/UV benefits? I've bought enough for the whole roof of my DC and will do it, but it does make me wonder. Likewise on the door panels. For sound in the roof I shall be using a light closed cell foam, and for the doors, if there's space, some ply. Floor will be covered in SC and Insulator matting. I start in one hours time, get a little bit done before the rugby Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #577255 12th Nov 2016 10:15am
Lew-M
Why not have a quick experiment on the doors covering one entirely and then another with a section around the centre of the panel or strategically placed. Then a simple slam test to see how they sound?may be interesting and informative for others looking to do the same? Thumbs Up
Cheers,
Lew
Post #577262 12th Nov 2016 10:25am
mse
The only reason i covered most of the floor area was to make it even for the mat/carpet - otherwise im not sure i would have bothered
At the end of the day no matter how much you cover, the glass isnt the range rover double glazed, doors dont seal properly, posts arent that accessible, so you will only get so much positive benefit. Mike
Post #577263 12th Nov 2016 10:29am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Ok perhaps I used the wrong terminology, instead of using soundproofing I should have used de-resonance and insulation. I can however confirm, after just done a 300 mile trip, it makes a big difference, really has cut down the resonance/booming and holds the warmth better. I had enough both the SC and closed cell foam to do the foot wells front and back, which I think also has helped. As far as noise levels go, up to 60mph, it's very nearly as quiet as our 300 disco, which is what I was aiming for.
Going to concentrate on doing the bulkhead and surrounding area next to cut engine and gear box noise. I've already fitted a noise killer engine blanket, which has made quite a difference, so doing the bulkhead and inside the dash should make it a lot quieter.
Post #577271 12th Nov 2016 10:52am
mk1collector
Doing the bulkhead won't make as big of a difference with the sound deadening as there are lots of angles and braces, so not as much resonance. The ccf will make a difference and I'd still add some sound deadening anyway. As for everyone saying you only need a small square in the middle of the panel, this will make a big difference to resonance but coming from a car stereo background, the more mass you add the less noticable the resonance is, so I feel a full covering is best in a vehicle with large flat panels. Ray
My build thread
Post #577288 12th Nov 2016 12:09pm
BuckBlu110
Agreed, full coverage may not be necessary, but sure does the job and helps. I doubt I'll use the SC on behind the dash, only on the larger flatter bits of the bulkhead, which there are few, and as you say, foam will do the coverage every where else under there. I'm thinking Closed cell on the bulkhead and open cell on the inside of the dash where no water can get at it and it isn't going to affect anything important.
Post #577440 13th Nov 2016 2:32am
Stiff1
Never think there is an area of the Defender that will not get wet...
Post #577563 13th Nov 2016 7:51pm
BuckBlu110
Mines leak free in that area so I'm not too worried Wink
Any way, the stuff I've got my eye on is supposed to dry out very quickly and easily, but we'll see, I'll make my mind up the next time the dash is out.
Post #577667 13th Nov 2016 11:45pm
Page 2 of 2 <12
