Home > Maintenance & Modifications > Soundproofing/de-resonance/insulating the roof
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Having read through various soundproofing threads, I've noticed that some people use two layers of the aluminium/butil based type sound proofing like silent coat that I've just purchased and am now half way through fitting.
Thinking about it, obviously the more material up there, the quieter it'll be, but surely, this sort of soundproofing is to reduce the drumming and resonating of a panel and then other material like foam to do the sound absorbing, which I'm also doing.
Basically what I'm asking is, is it worth me covering the roof twice with the silent coat and then a layer of closed cell foam, or will one layer of the silent coat be enough as, as long as it's there it doing the job, and then add the foam afterwards?
Hope all this makes sense Confused
Post #576359 8th Nov 2016 9:18pm
Profyaffle
Hi, I have found that one coat of silent coat is enough. I previously did a classic mini and more recently my defender. As you said, the bitumen coat to kill the resonance and the closed cell foam to absorb any other noise. Theoretically the bitumen coat doesn't need to cover the entire panel but it does look better Very Happy
Julia
Post #576371 8th Nov 2016 9:45pm
BuckBlu110
Brilliant, thank you, I can use the left over bits elsewhere then.
Did you find it makes much of a difference doing the roof?
Post #576397 8th Nov 2016 11:32pm
mk1collector
I did two layers on mine which does make a bigger difference but one layer will be fine. I also added two layers of ccf and it's a lot quieter when driving now. Ray
My build thread
Post #576407 8th Nov 2016 11:54pm
BuckBlu110
Cheers Ray, that's good to know, cut fingers won't be in vein then! Laughing I suppose it makes sence that the thicker the layers and the more of them the more effective it will be. I've got 12mm closed cell foam to go on top of the 2mm silent coat too.
Post #576411 9th Nov 2016 12:01am
Profyaffle
I've found every little helps especially on the bigger panels. Whilst I did the whole of the mini interior with SC I haven't done in the rear of the defender as the paintwork was so nice so I am putting up with some noise. I fitted a full rubber mat over the load floor and wheel arches and put Mud stuff side panels on. I stuck some SC under the front headlining and round the bulkhead, seat box and inside the door panels then fitted the moulded mat from Exmoor trim.
Post #576455 9th Nov 2016 9:37am
mcma1
I did my entire roof with Skinz and the 6mm foam. after a few months i was fitting the overhead DVD and the headliner had to come down, 90% of the sound proofing have peeled away. The heat on the inner surface of the roof was surprising and the black backing was so soft. Only that i was adding the DVD i would NEVER have known so just be aware. I replaced it all with dynamat which is a thinner layer and after a recent check its all still in place. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #576621 9th Nov 2016 9:46pm
BuckBlu110
Cheers Andy, I'll steer clear of that skinz stuff. I'm hoping the silent coat will do the job, I've read good things about it.
Post #576705 10th Nov 2016 12:02am
Stacey007
I'm using silent coat 2mm on mine with 8mm foam (around the car parts)
I've yet to do the roof...
It worried me taking the headlining off... and getting it back on Sad
Is it an ok job?
Post #576744 10th Nov 2016 10:39am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Easy to take off, slightly awkward to handle by yourself and put back on. 2nd pair of hands helps.
Suggest you buy replacement fir-tree clips before you start as you are bound to break some.
Post #576765 10th Nov 2016 12:01pm
BuckBlu110
^^^ this, it also bends a lot easier than you think it would, just be carful not to crease it.
Post #576772 10th Nov 2016 12:32pm
Stacey007
If I attack this I might dig out my tri pod as a third hand Smile
Or build a little frame out of wood? to support it
Post #576773 10th Nov 2016 12:34pm
BuckBlu110
Got all the soundproofing in on the roof, with a bit spare to do the 2nd row foot well and front foot wells. we shall see how much of a difference it has made tomorrow.
Post #577012 10th Nov 2016 11:46pm
g-mack
i used 2mm silent coat, and doubled up in centre of panels, then auto grade 3m thinsulate Thumbs Up
worked a treat, used to sound like a 747 on take off at 70 mph.
now sounds more like 737!!!! Laughing
 My 109 thread
my youtube channel
Post #577043 11th Nov 2016 9:43am
mse
Ignoring we have the black "premium" headlining...i dont see any value in doing the roof and wouldnt waste time dropping the headlining...but the black headlining is definitely thicker than the standard Mike
Post #577111 11th Nov 2016 2:09pm
