Home > Td5 > Headlamp bulb upgrade suggestions please
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, my 2001 TD5 has candles for bulbs. Although I would like to go down LED route I feel I have to spend my cash on more urgent Landy parts.
Are there any recommendations simply for a bulb upgrade?
Thanks in advance Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #576342 8th Nov 2016 8:31pm
Bluest
I recently did the tried and tested relay loom/crystal lamps/Nightbreaker bulb combo. Night and day difference over the standard lights. You can do the whole lot for easily less than £100. 2007 110 TDCi Station Wagon XS
Post #576346 8th Nov 2016 8:35pm
excossack
I have just crystal lamps/Nightbreaker bulb combo and certainly a clear difference. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #576348 8th Nov 2016 8:40pm
VeeTee
Netherlands
Philips Extreme Vison bulbs, in combination with Crystal Clear Headlamp and relay loom - a huge difference compared to standard setup... Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #576361 8th Nov 2016 9:26pm
^^^^ This, but I'm looking to go LED shortly. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #576369 8th Nov 2016 9:43pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
These ...
http://fourby.co.uk/epages/950004277.sf/en...ucts/LEDH4
LED performance without the LED cost.
Did mine , did a couple of mates too, bloody brilliant! Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #576388 8th Nov 2016 10:40pm
VeeTee
Netherlands
^ but not street legal... Shocked Cheers, Vincent
MySite
Post #576389 8th Nov 2016 10:48pm
Dave-H
Grey area, but Who cares??
No different to numerous other motors with led headlights, passes the mot without any issues, and not even road policing officers are aware of them being legit or not [I've checked] Guns and Landrovers .... anything else is irrelevant.
Post #576505 9th Nov 2016 1:38pm
MC84
Thanks for all the input, I'll let you know how it goes. Thanks again.... Thumbs Up Mike
Ford 100e 1959
Post #576600 9th Nov 2016 8:51pm
MC84
I went for the Philips and they have made a big difference. I didn't change the lamp unit just the bulbs, I'll wait and see what Santa brings! Mike
Ford 100e 1959
Post #579052 19th Nov 2016 9:06pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If have not already I highly recommend you add a wiring loom with relays to the light switch. Brand name like Boomslang is expensive but this will mae your lights brighter and allow the switch to last much, much longer. As for bulbs I have no prefence, what ever is on sale, usually Osram... 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #579181 20th Nov 2016 2:18pm
MC84
I had assumed they were on a relay, so they are not? I was also going to check the voltage at the bulb. I'm guessing there is a bit of a drop. So a relay loom would overcome this I'm thinking?
Thanks for the advice, I'm on it!!! Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #579204 20th Nov 2016 5:11pm
4RF RDS
The switch is not. Full voltage goes through it and burns it out (literally). The additional loom corrects this and adds a low and high beam relay with ceramic plugs to the lights allowing higher wattage (if you like) and takes the voltage away from the switch. It is basically plug and play. This is the one I installed over a year ago. These are cheap but I put a few in a few different Defenders and these work great.
http://www.ebay.ca/itm/H4-9003-Headlight-R...amp;_uhb=1 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #579241 20th Nov 2016 7:37pm
MC84
Thanks for the loom advice. I'll think that will have to go on the list. Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #579299 20th Nov 2016 10:28pm
MC84
Just as a belated update I fitted an ungraded loom last year and am now getting about 14v at the "bulb" end when on and loaded. In the last couple of weeks I have fitted Wipac Crystal headlamps and Ring Xeon 150+ bulbs and what a difference it makes! I can now see I have the headlights on as before you really couldn't tell.
I'm sure good LED headlamps will be the way to go once funds permit. Mike
Ford 100e 1959
Post #747986 29th Dec 2018 10:37pm
