Home > Td5 > Heated seats
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Heated seats
Now winters upon us, there's a few things that need looking at that I swore I'd do before i needed them Laughing first one is my heated seats, they used to get really hot, now the passenger seat is just warm, and the drivers side doesn't work at all?
Questions
What controls the heating limit? Has it a thermostat connected somewhere?
And although I have supply to the drivers side coming in from the seat box it disappears up into the backrest (that doesn't work) but I could only test the seat connection which is dead? Does it daisychained somehow, and how difficult is it to get to the backrest connection
Ta 2005 TD5 90 CSW XS
Post #576072 7th Nov 2016 6:05pm
dorsetsmith
What controls the heating limit? thermostat connected in seat heat pad
power is only on with engine running
Post #576079 7th Nov 2016 6:26pm
Kent_keith
Thank you Mr Smith Very Happy are you sure it's for a 2005 as as I've got power there without the engine running? 2005 TD5 90 CSW XS
Post #576086 7th Nov 2016 6:47pm
Romadog
Wiring is correct for 2005.
Are you sure you are checking the right plug?
One connects to seatbase and joins to seatback element and the other connects to plug coming through seat box.
Post #576087 7th Nov 2016 6:52pm
Kent_keith
It comes up from the drivers side seat box, then connects to the back rest, then comes back to the seat? 2005 TD5 90 CSW XS
Post #576089 7th Nov 2016 6:56pm
dorsetsmith
yes as from 2002 wiring stayed same to 2006 for LR fitted wire loom so that not battery drain with out engine running and DC alt charging the battery
Post #576090 7th Nov 2016 6:58pm
Kent_keith
I have voltage there without the engine running? About 11.5volts without the engine running, but about 14 volts with it running, 2005 TD5 90 CSW XS
Post #576092 7th Nov 2016 7:10pm
dorsetsmith
i tack it you have key in and tuned to position 2 so that ( relay ignition / heated seat, window lift number 6 in passenger fuse box) can close contact and the switch on the centre dash switch on
Post #576098 7th Nov 2016 7:42pm
Kent_keith
Yes that's correct thank you, can anyone tell me how to inspect the connection for the backseat as I need to look at this first Very Happy 2005 TD5 90 CSW XS
Post #576175 8th Nov 2016 8:35am
dorsetsmith
two heat pads pre seat 2.1 ohms N/C thermostat opens heat up in bottom part of seat
1. open cct heat pads or open cct wiring or thermostat failed open all time
2. seat covers will need to be removed to check all pints in number 1
Exmoor trim video show's the way de construct the seat
http://www.exmoortrim.co.uk/videos
Post #576190 8th Nov 2016 10:21am
Martin
Site Admin
Heated seats operate with ignition on, there is no engine run signal or feed involved in the heated seat circuits.
The front heated windscreen is only operational with the engine running, perhaps this is where the confusion has come in.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #576194 8th Nov 2016 10:35am
