![]() | Home > Td5 > Heated seats |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge What controls the heating limit? thermostat connected in seat heat pad power is only on with engine running |
| Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388
Thank you Mr Smith
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
Wiring is correct for 2005.
Are you sure you are checking the right plug? One connects to seatbase and joins to seatback element and the other connects to plug coming through seat box. |
It comes up from the drivers side seat box, then connects to the back rest, then comes back to the seat? 2005 TD5 90 CSW XS
yes as from 2002 wiring stayed same to 2006 for LR fitted wire loom so that not battery drain with out engine running and DC alt charging the battery
I have voltage there without the engine running? About 11.5volts without the engine running, but about 14 volts with it running, 2005 TD5 90 CSW XS
i tack it you have key in and tuned to position 2 so that ( relay ignition / heated seat, window lift number 6 in passenger fuse box) can close contact and the switch on the centre dash switch on
Click image to enlarge |
Yes that's correct thank you, can anyone tell me how to inspect the connection for the backseat as I need to look at this first
two heat pads pre seat 2.1 ohms N/C thermostat opens heat up in bottom part of seat
1. open cct heat pads or open cct wiring or thermostat failed open all time 2. seat covers will need to be removed to check all pints in number 1 Exmoor trim video show's the way de construct the seat http://www.exmoortrim.co.uk/videos |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Heated seats operate with ignition on, there is no engine run signal or feed involved in the heated seat circuits.
The front heated windscreen is only operational with the engine running, perhaps this is where the confusion has come in. Martin 1988 90 Td5 NAS soft top
2015 D90 XS SW |
