![]() | Home > Td5 > Clutch modification |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3260 ![]() ![]() |
It does make a noticeable difference and makes the Defender easier to drive.
Fitted as standard to TDi and Puma but bizarrely not the TD5. |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Martin
What parts do I need and where do I get them? Ta |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
Tank,
Here is the one I ordered. When it came it was actually a Britpart one. Easy to fit just need a pair of long nose pliers. http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3f25dcfdb4 Hope this helps ![]() |
Thanks Martin.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
One of the best mods to do! Love it on mine...
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Here's the same Britpart from Paddocks
http://www.paddockspares.com/clutch-pedal-...ender.html Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Exactly the same as the one I fitted but a cheaper price
![]() Only just by the time you add the £5 postage on it as order is less than £60. ![]() |
Rugbier Member Since: 26 Nov 2012 Location: USA Posts: 3 ![]() ![]() |
Any guidance how to switch this part?
True, but I usually "save" the small parts order until it achieves the magical £60 threshold! Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
It's all in here ![]() ![]() https://thegippo.wordpress.com/2014/10/18/td5-clutch-pedal-mod/ |
So the top bush snapped when putting it in. Fk
Can you buy the plastic buses separately ? |
