![]() | Home > Maintenance & Modifications > Mudflap rivnut help needed! |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Screw a longer bolt into it with a nut already on the bolt, hold the bolt head with a spanner and gently tighten the nut and it will compress the riv nut, don't over tighten but nip it up so it grips.
Hope that solves it… |
You can probably reset the rivnut so that it grips the hole again. Use either a proper rivnut tool or a bolt, a couple of nuts and three hands. Darren
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
i used normal nuts and bolts; you can just about get your hand in there; i used stainless with nyloc nuts and plenty of copper greese.
To get rid of the spinning riv nut, they easily knock inside if you use a punch from the outside to be retrieved by hand, and don't damage the hole so could be replaced with new ones later on. |
