Home > Maintenance & Modifications > Mudflap rivnut help needed!
Mwd
So, I naively took off one of my front mudflaps to repaid the bracket and now I can't get the bu99er back on. One of the rivnuts is loose and spins when I try to tighten the bolt. I can't get a decent grip on it with pliers and I'm hoping someone can advise a technique to get the bolt tightened up.
Post #575025 2nd Nov 2016 9:21pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Screw a longer bolt into it with a nut already on the bolt, hold the bolt head with a spanner and gently tighten the nut and it will compress the riv nut, don't over tighten but nip it up so it grips.
Hope that solves it…
Post #575035 2nd Nov 2016 10:07pm
You can probably reset the rivnut so that it grips the hole again. Use either a proper rivnut tool or a bolt, a couple of nuts and three hands. Darren
Post #575036 2nd Nov 2016 10:09pm
V8GPC
i used normal nuts and bolts; you can just about get your hand in there; i used stainless with nyloc nuts and plenty of copper greese.
To get rid of the spinning riv nut, they easily knock inside if you use a punch from the outside to be retrieved by hand, and don't damage the hole so could be replaced with new ones later on.
Post #575093 3rd Nov 2016 8:02am
