Home > Maintenance & Modifications > On-Board Air
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
On-Board Air
hi guys, I'm after recommendations for a good on board compressor. Plan is to mount it permanently in the drivers seat box ( space dependant - can't remember how busy it is in there!)
I've seen cheap T-max ones etc, and I'd rather pay for something that'll last.
Plan is t mount an air line connector in the seat box, so I can just connect a coiled air line to it, when i require it. Powere will be from a Carling switch on the dash.
Any advice / suggestions welcome.
Only makes I can think of are Vi-Air, Warn, and ARB.
Post #57496 7th Feb 2011 8:23pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Get a Viar off Matt Savage Thumbs Up
Post #57500 7th Feb 2011 8:25pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Ive got an ARB heavy duty one under my drivers seat and store the airline under there, it's a little tight but does fit. Obviously drives the difflock as well. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57502 7th Feb 2011 8:26pm
Mike_B
Not got a diff-lock just yet, but may end up with one in the future. Do you guys have air tank /reservoir too? what's the benefit - presume it's just a bit quicker to pump tyres up etc and you may be able to run air tools off it if the tanks big enough...
Post #57506 7th Feb 2011 8:31pm
willy eckerslike
I haven't got an air tank, the compressor is quick enough for pumping up tyres, though I don't think you could use it to pop a bead back on. Airtools... just go electric nowadays. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #57507 7th Feb 2011 8:34pm
leeds
On red 110 300 TDi we have an engine mounted compressor, a 9 litre air tank under floor. The pressure gauge/switch is mounted just by O/S middle door with a long coil airline n the cargo barrier.
The tank will hold 150 psi/10 bar.
From stopping, inflating all tyres from 20psi to 38 psi takes about 8 minutes to moving off.
Just be careful using high pressure/high volume on diff lockers as they can create problems
Brendan
Post #57537 7th Feb 2011 9:20pm
