Home > Maintenance & Modifications > Cleaning Crud out above rear crossmember
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
The rear fog light was not working so took it out to check the bulb and was surprised how much crud there was in there a goo cm of so caked up behind the light. Does anyone have any tips on how to clear this out all the way along as I assume it is caked all the way across the back.
Thanks
Adam
Post #574379 30th Oct 2016 4:09pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Other than getting in there with a screwdriver and a pressure washer whilst getting very wet I don't think that there are many other options. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #574383 30th Oct 2016 4:18pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I have cut down a couple of old rubber floor mats and attached them at the top of there going all the way down to the bottom of the cross member, reduces the crud significantly. Thumbs Up 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #574397 30th Oct 2016 5:19pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I've used screwdriver and compressor Very Happy
Post #574427 30th Oct 2016 6:59pm
Cupboard
Screwdriver compressor and paint brush for me.
Post #574445 30th Oct 2016 8:13pm
Alien
Australia
On our 110 there is a plastic trim that can be removed from under the gaurd.
This gives access to the fog light plinth nuts and the wireing.
I've fitted a locker in the LH void and there are water tanks that fitt there too.
By doing this access is not possible except by removing the lights.
To allow this I converted the reverse light plinth from rear nuts to Nutserts.
I've also converted my fog lamp to a reverse but not sure this would meet your MOD requirements. Cheers,
Kyle.
Post #574462 30th Oct 2016 9:13pm
miker
Pressure washer and stand as far to one side as you can!
Post #574480 30th Oct 2016 10:40pm
Screbble
As above plus a small bottle brush (not the plant!) Thumbs Up
Post #574506 31st Oct 2016 8:39am
