![]() | Home > Maintenance & Modifications > Cleaning Crud out above rear crossmember |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Other than getting in there with a screwdriver and a pressure washer whilst getting very wet I don't think that there are many other options. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
| Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492
I have cut down a couple of old rubber floor mats and attached them at the top of there going all the way down to the bottom of the cross member, reduces the crud significantly.
1994 Def 90 300tdi |
| Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830
I've used screwdriver and compressor
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Screwdriver compressor and paint brush for me.
| Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230
On our 110 there is a plastic trim that can be removed from under the gaurd.
This gives access to the fog light plinth nuts and the wireing. I've fitted a locker in the LH void and there are water tanks that fitt there too. By doing this access is not possible except by removing the lights. To allow this I converted the reverse light plinth from rear nuts to Nutserts. I've also converted my fog lamp to a reverse but not sure this would meet your MOD requirements. Cheers, Kyle. |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
Pressure washer and stand as far to one side as you can!
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
As above plus a small bottle brush (not the plant!)
| All times are GMT |
