![]() | Home > Td5 > Ignition switched supply under seats. |
| Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121
I'm thinking of running some switches from the cubby box to supply heated seats and some additional electrical items. Is there a convenient ignition switched supply I can safely tap into in this area? How about from the ECU compartment? I would use it to trigger relays while drawing the main juice from the battery directly.
Any thoughts guys? 1999 Td5 110 CSW 1961 Series 2 88 LPG |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
white 4.0mm wire Ignition switched supply only runs down to centre fuse box
Ignition relay and wiring added to control heated seats power supply this wiring only in place from 2002 onwards
white 4.0mm wire Ignition switched supply only runs down to centre fuse box the only other from fuse 4 centre fuse box green / orange wire for ABS control unit under driver seat box, wire may be in place it is switch by the Ignition ! for 1999 to 2001 defender as wiring loom changes from 2002 onwards Last edited by dorsetsmith on 29th Oct 2016 6:06pm. Edited 1 time in total |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
There are several options in the fuse box 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| All times are GMT |
