Home > Td5 > Ignition switched supply under seats.
Loz2286
I'm thinking of running some switches from the cubby box to supply heated seats and some additional electrical items. Is there a convenient ignition switched supply I can safely tap into in this area? How about from the ECU compartment? I would use it to trigger relays while drawing the main juice from the battery directly.
Any thoughts guys? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #574149 29th Oct 2016 1:11pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I gave up Shocked and ran switched wires from the dash console where I installed my switches as well. I ran the wires under the floor sound mat and under the seat box matting to the seats. Watching for future reference. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #574176 29th Oct 2016 4:19pm
dorsetsmith
white 4.0mm wire Ignition switched supply only runs down to centre fuse box
Post #574181 29th Oct 2016 4:38pm
dorsetsmith
Ignition relay and wiring added to control heated seats power supply this wiring only in place from 2002 onwards
the only other from fuse 4 centre fuse box green / orange wire for ABS control unit under driver seat box, wire may be in place it is switch by the Ignition ! for 1999 to 2001 defender as wiring loom changes from 2002 onwards
Post #574184 29th Oct 2016 4:46pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
There are several options in the fuse box 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #574221 29th Oct 2016 6:59pm
