Home > Td5 > Heater blower fault. Intermittent at first and now nothing
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
I wonder if anyone can help me fault find a fault with my heater blower.
The blower was intermittent and only ran consistently when the engine was above idle. Now its not running at all.
I think the issue may be the dash switch but I have no idea how to get at it.
Has anyone else had this issue? Also any advice on getting to the switch?
My wipers have also started playing up and are not returning to park from intermittent. Both faults appeared yesterday! Coldest and wettest day of the year so far!
Post #573398 25th Oct 2016 10:08pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
undo the 4 screws that hold the instrument binnacle on. two by your knees the other two are at the top left and right hand sides by the sliders.
remove the clocks and the fan controls are on the left.
Dodgy the fan sound OK prior to stopping? if so check the switch contacts on the slider and give them a clean.
If not remove the air intake and try and turn the fan by hand
Mine seized only a few months ago and needed replacing 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #573444 26th Oct 2016 1:38am
Mo Murphy
If the fan is seized you can try spraying wd40 into it and turning by hand until it loosens up, that may save you forking out for a new fan, as this is a fairly common problem.
HTH
50 Shades of Pennine Grey
Post #573485 26th Oct 2016 11:25am
mactheknife
Thank you both. I'll give it a go and report back!
Post #573617 26th Oct 2016 7:57pm
mactheknife
OK. I've had the instrument panel off and found the switch. I can get the blower running in position one, but not two. The switch looks clean and uncorroded. Haven't put a multimeter to it yet though.
Post #573629 26th Oct 2016 8:26pm
dorsetsmith
The heater blower lever arm is push up to the contacts by small spring and ball baring
Post #573635 26th Oct 2016 8:43pm
VeeTee
Netherlands
deleted Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #573640 26th Oct 2016 8:48pm
mactheknife
Thanks Dorset. I think there may be a bad connection between the sprung contact and position 2. Will get some wet and dry paper in there tomorrow.
Post #573683 26th Oct 2016 10:20pm
