![]() | Home > Td5 > Heater blower fault. Intermittent at first and now nothing |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
undo the 4 screws that hold the instrument binnacle on. two by your knees the other two are at the top left and right hand sides by the sliders.
remove the clocks and the fan controls are on the left. Dodgy the fan sound OK prior to stopping? if so check the switch contacts on the slider and give them a clean. If not remove the air intake and try and turn the fan by hand Mine seized only a few months ago and needed replacing 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2387 ![]() ![]() ![]() |
If the fan is seized you can try spraying wd40 into it and turning by hand until it loosens up, that may save you forking out for a new fan, as this is a fairly common problem.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 ![]() ![]() ![]() |
Thank you both. I'll give it a go and report back!
OK. I've had the instrument panel off and found the switch. I can get the blower running in position one, but not two. The switch looks clean and uncorroded. Haven't put a multimeter to it yet though.
![]() Click image to enlarge The heater blower lever arm is push up to the contacts by small spring and ball baring Last edited by dorsetsmith on 26th Oct 2016 8:53pm. Edited 1 time in total |
deleted Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks Dorset. I think there may be a bad connection between the sprung contact and position 2. Will get some wet and dry paper in there tomorrow.
