![]() | Home > Td5 > 2001 TD5 Front screen replacment. More advice please |
| MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360
Hi, I have the front windscreen frame out on the bench. I'm repairing the bulkhead and replacing the window and a few other seals to try to keep the water out. A little advice please.
1) Would you fit the glass and seal to the frame while the frame its on the bench? I'm thinking it would be easier if the frame in in the car so I won't have to chase it around the bench. 2) The windscreen seal, pic2 below. Sorry to be stupid, I just want to confirm which side goes out, which side goes in! 3) In pic1 you may just be able to see a lip in the lower part of the seal. Is this important? Should the glass go in this. The lip is right at the bottom of the two sides. It's only a few mm high. 4) When the seal is fitted, (pic4) should the join be top or bottom when in the frame? The picture aren't great and would be happy to submit more if that would help Thanks for looking at my stupid questions! Click image to enlarge[/URL] [/img][URL=] Click image to enlarge[/URL] Click image to enlarge[/URL] [/img][URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
this may help you
https://www.google.co.uk/search?q=defender...hCQtQHM%3A |
dorsetsmith, thanks for the links, I shall study them, very useful, I'll let you know how I get on and
excossack, if its no bother the more information I have the better! I will be at the point of fitting next Monday. Fingers crossed!!! Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Ok slipped into the full sou'wester, donned the thermal boots, braved the sub zero arctic elements and fought off a large polar bear or two and got to the shed.
The join on mine is the bottom of the screen. There is a indent that runs the full length of the rubber, this on the outside. The middle picture is looking into the top right corner of the screen / passenger side Click image to enlarge Click image to enlarge Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Top work thank you very much. Good luck with the polar bears on the future! Mike
| All times are GMT |
