Home > Td5 > 2001 TD5 Front screen replacment. More advice please
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, I have the front windscreen frame out on the bench. I'm repairing the bulkhead and replacing the window and a few other seals to try to keep the water out. A little advice please.
1) Would you fit the glass and seal to the frame while the frame its on the bench?
I'm thinking it would be easier if the frame in in the car so I won't have to chase it around the bench.
2) The windscreen seal, pic2 below. Sorry to be stupid, I just want to confirm which side goes out, which side goes in!
3) In pic1 you may just be able to see a lip in the lower part of the seal. Is this important? Should the glass go in this. The lip is right at the bottom of the two sides. It's only a few mm high.
4) When the seal is fitted, (pic4) should the join be top or bottom when in the frame?
The picture aren't great and would be happy to submit more if that would help
Thanks for looking at my stupid questions! Thumbs Up Thumbs Up
[/img][URL=]
[/img][URL=]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #573361 25th Oct 2016 7:59pm
dorsetsmith
Post #573366 25th Oct 2016 8:11pm
excossack
I didn't fit my windscreen, but when the paint shop tried it, they decided it was safer and easier to fit the screen in the car as the frame was effectively clamped down and could not move.
I have my old frame & glass in the shed so can take a picture if you want of the seal? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #573367 25th Oct 2016 8:13pm
MC84
dorsetsmith, thanks for the links, I shall study them, very useful, I'll let you know how I get on and
excossack, if its no bother the more information I have the better!
I will be at the point of fitting next Monday. Fingers crossed!!! Mike
Ford 100e 1959
Post #573369 25th Oct 2016 8:23pm
excossack
Ok slipped into the full sou'wester, donned the thermal boots, braved the sub zero arctic elements and fought off a large polar bear or two and got to the shed.
The join on mine is the bottom of the screen.
There is a indent that runs the full length of the rubber, this on the outside.
The middle picture is looking into the top right corner of the screen / passenger side
Regards
John M0VAZ
Post #573372 25th Oct 2016 8:32pm
MC84
Top work thank you very much. Good luck with the polar bears on the future! Mike
Ford 100e 1959
Post #573383 25th Oct 2016 9:15pm
