![]() | Home > Td5 > Bulkhead swap |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
If you could take a pic or two when you get the old bulkhead back it would be much appreciated. I will be replacing my windscreen surround in the next few months so a couple of pics would be a good heads up
![]() My build thread http://www.defender2.net/forum/topic17615.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5763 ![]() ![]() ![]() |
Saw the 110 to day, Wings on and aligned, bonnet, grill all back on. Windscreen frame back in place - just needs bolting down and glass going in.
Hopefully back with me tomorrow. @Mk1Collector - do these pics help? ![]() Click image to enlarge ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Absolutely perfect thanks
No worries, As you can see a bit of rust. Was offered £100 for it...not sure, I think it might be worth more. 1999 Defender TD5 110
110 is back!
Just two issues. Radio not working and washer jet on drivers side not working. Radio fixed but the washer jet, I think the pipe has come off and is leaking.... ![]() Apart from that all good. Plus I got to drive a TD5 110 with a slick shift fitted = ![]() ![]() Regards John M0VAZ Econet Station 48 no clock |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 ![]() ![]() ![]() |
Mk1collector, this is my Defender 2001. I had the frame out and was thinking these might help you:
Apologies for the upside/sideways images. I blame Photobucket! ![]() Click image to enlarge[/URL] [/img] ![]() Click image to enlarge[/URL] [/img][URL=] ![]() Click image to enlarge[/URL] ![]() Click image to enlarge[/URL] [/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Excellent thanks
I'm changing the thick black rubber/foam strips at the back running under the tub so I unbolted or loosened all of the rear ones as well. I think you need to do this anyway to allow clearance for the screen/frame to fall into the cab slightly so it can be lifted off the locators/pegs. Mike
I think when mine was done, at least the bolts for the front of the roof got removed which I think gives enough movement to remove with out undoing all. 1999 Defender TD5 110
Good to know for next time.
Thanks chaps
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
