Home > Td5 > Heated Screen Switch
Morepower
New Zealand
One for the TD5 guys on here, I've ordered a Heated Screen switch and its arrived but it's not latching... I presume it should be?... Just wanted to check before going back to the supplier
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #568402 3rd Oct 2016 12:59pm
I don't think the switch latches. Instead, it drives a latching relay, which is in turn controlled by a timer. Darren
Post #568405 3rd Oct 2016 1:13pm
landroverdiver
Mine latches, and if I remember correctly illuminates. Unfortunately that's all that happens as the heated screen needs repaired or replaced!
Nope, I'm wrong it doesn't latch, sorry
Post #568406 3rd Oct 2016 1:14pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Hi. Timed relay for the heated screen, as the others have said. You have the right switch Very Happy
Tony
Post #568410 3rd Oct 2016 1:27pm
Martin
Site Admin
Heated FRONT screen switch does not latch - it triggers a timer unit.
Heated REAR screen switch does latch  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #568411 3rd Oct 2016 1:30pm
Morepower
New Zealand
Thanks Guy's spoke to the supplier, Seems they've sent me a Discovery TD5 Heated rear screen switch instead of a Defender one...
Mystery sorted
Thanks
Post #568436 3rd Oct 2016 5:26pm
The timer unit is the same as used on the classic rangies (well, that's what I've got on mine). although mine has died, must get another sometime.
I might just get a generic one from durite, as the RR one seems rare and expensive. I also wired my heated wingmirrors into it (via a relay) so they come on for the duration of the screen, which is about 12minutes IIRC
Post #568819 5th Oct 2016 9:33am
Martin
Site Admin
The proper timers do come up on eBay for reasonable money, I've had two from there.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #568827 5th Oct 2016 10:29am
