![]() | Home > Td5 > Heated Screen Switch |
I don't think the switch latches. Instead, it drives a latching relay, which is in turn controlled by a timer. Darren
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Mine latches, and if I remember correctly illuminates. Unfortunately that's all that happens as the heated screen needs repaired or replaced!
Nope, I'm wrong it doesn't latch, sorry |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Hi. Timed relay for the heated screen, as the others have said. You have the right switch
![]() Tony |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6703 ![]() ![]() ![]() |
Heated FRONT screen switch does not latch - it triggers a timer unit.
Heated REAR screen switch does latch ![]() ![]() |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Thanks Guy's spoke to the supplier, Seems they've sent me a Discovery TD5 Heated rear screen switch instead of a Defender one...
Mystery sorted Thanks Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6213 ![]() ![]() ![]() |
The timer unit is the same as used on the classic rangies (well, that's what I've got on mine). although mine has died, must get another sometime.
I might just get a generic one from durite, as the RR one seems rare and expensive. I also wired my heated wingmirrors into it (via a relay) so they come on for the duration of the screen, which is about 12minutes IIRC |
The proper timers do come up on eBay for reasonable money, I've had two from there.
