![]() | Home > Maintenance & Modifications > Which Landreiziger Loom? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
I'm going to put in a headlight relay loom from Landreiziger.nl and there are three options, not sure which is one to get.
Plastic connectors https://shop.landreiziger.nl/lichtversterk...elais.html Ceramic connectors https://shop.landreiziger.nl/lichtversterk...toren.html Removable Hella connectors https://shop.landreiziger.nl/lichtversterk...toren.html Any suggestions? 2007 110 TDCi Station Wagon XS |
Use option 1 or option 2. Option 2 with ceramic H4 plugs is even cheaper. Option 3 is with removable H4 plugs, no need for that with a Defender.
Rgds, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I'm looking at getting a loom made here in the U.K. through a chap on Angry Puma's FB group, but if that doesn't come off I'll be buying direct from Landreiziger. And, based on these replies, I'll get the ceramic connectors. 2007 110 TDCi Station Wagon XS |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 671 ![]() ![]() |
What's wrong with just buying one of these?...
http://www.paddockspares.com/boomslang-per...-loom.html ![]() Click image to enlarge |
There's a few comments about that suggest the quality of the boomslang one can be a bit variable. 2007 110 TDCi Station Wagon XS
I have a Boomslang one that is wired incorrectly I.e. The wire colours not correct and earth too small a gauge in comparison to power wires.
Maybe a copy though, no idea I didn't purchase it myself it was a gift. I was thinking of wiring back to battery but now realise the benefits of supply from alternator direct with a shorter cable run, less voltage drop. Does the Land Reiziger have mounting tabs for the relays? (Not sure of their exact name) The ceramic connectors are a good thing to reduce heat and prevent any melting that plastic connectors could suffer from. I don't think that is a common issue but prevention is a good idea. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
Check the connections before installing if you get a boomslang. I pulled out a wire from a poorly crimped spade connector with just a gentle tug. Easily rectified on the bench - a pain once installed. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
Every other manufacturer does fine with plastic connectors, it's only 5A!
I will relay feed mine when I get a chance, I'll just hack up the existing loom however. |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Not sure where I purchased it or what it cost me. But it was surplus to needs so gifted. 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
