Home > Maintenance & Modifications > Which Landreiziger Loom?
Bluest
I'm going to put in a headlight relay loom from Landreiziger.nl and there are three options, not sure which is one to get.
Plastic connectors https://shop.landreiziger.nl/lichtversterk...elais.html
Ceramic connectors https://shop.landreiziger.nl/lichtversterk...toren.html
Removable Hella connectors https://shop.landreiziger.nl/lichtversterk...toren.html
Any suggestions? 2007 110 TDCi Station Wagon XS
Post #565883 22nd Sep 2016 9:15pm
I'd say ceramic if your using incandescent lights and plastic or ceramic if LED.
May as well go ceramic.
Are you buying direct? This is the one I'd be interested in over alternatives as it's been highly recommended.
H4 connectors are standard on a Defender. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #565889 22nd Sep 2016 9:32pm
ericvv
Post #565910 22nd Sep 2016 10:08pm
Bluest
I'm looking at getting a loom made here in the U.K. through a chap on Angry Puma's FB group, but if that doesn't come off I'll be buying direct from Landreiziger. And, based on these replies, I'll get the ceramic connectors. 2007 110 TDCi Station Wagon XS
Post #565929 22nd Sep 2016 10:43pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
What's wrong with just buying one of these?...
http://www.paddockspares.com/boomslang-per...-loom.html
Post #565934 22nd Sep 2016 10:49pm
Bluest
There's a few comments about that suggest the quality of the boomslang one can be a bit variable. 2007 110 TDCi Station Wagon XS
Post #565939 22nd Sep 2016 10:55pm
I have a Boomslang one that is wired incorrectly I.e. The wire colours not correct and earth too small a gauge in comparison to power wires.
Maybe a copy though, no idea I didn't purchase it myself it was a gift.
I was thinking of wiring back to battery but now realise the benefits of supply from alternator direct with a shorter cable run, less voltage drop.
Does the Land Reiziger have mounting tabs for the relays? (Not sure of their exact name)
The ceramic connectors are a good thing to reduce heat and prevent any melting that plastic connectors could suffer from.
I don't think that is a common issue but prevention is a good idea. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #565953 22nd Sep 2016 11:14pm
Leviathan
Check the connections before installing if you get a boomslang. I pulled out a wire from a poorly crimped spade connector with just a gentle tug.
Easily rectified on the bench - a pain once installed.
Post #565981 23rd Sep 2016 8:06am
miker
Every other manufacturer does fine with plastic connectors, it's only 5A!
I will relay feed mine when I get a chance, I'll just hack up the existing loom however.
Post #565985 23rd Sep 2016 8:23am
walfy
Not sure where I purchased it or what it cost me. But it was surplus to needs so gifted. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #566145 23rd Sep 2016 9:33pm
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #566148 23rd Sep 2016 9:40pm
