![]() | Home > Technical > Cold Cranking Amps (CCA) in a standard Def Battery? (puma) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
std pum is more than that, 750 or 800CCA IIRC Cheers
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
^^^^ That sounds about right 880 or similar seems to spring out in my mind. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
It's a wet battery made by Varta, size 019.
I'd have said 850CCA and 90Ah but it's something like that anyway ![]() |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Thanks guys.
More than enough for the winches I'm looking at ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
You know you want a second battery regardless, dont you
On the list...
