Home > Technical > Cold Cranking Amps (CCA) in a standard Def Battery? (puma)
agentmulder
Kuwait
A winch I'd like calls for a battery specced to deliver 650 CCA.
I'm away from my vehicle at the moment and cant check what it has in there...
It's a 2008 110 Puma.
Do we have at least that spec for the sake of the starter motor?? Solved the bowel problem, working on the consonants...
Post #565311 20th Sep 2016 9:36am
jst
std pum is more than that, 750 or 800CCA IIRC Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #565322 20th Sep 2016 10:00am
^^^^ That sounds about right 880 or similar seems to spring out in my mind. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #565325 20th Sep 2016 10:05am
Cupboard
It's a wet battery made by Varta, size 019.
I'd have said 850CCA and 90Ah but it's something like that anyway Laughing it's not beyond the realms of possibility that the exact spec has changed over the years that they've been doing the Puma.
Post #565353 20th Sep 2016 11:59am
agentmulder
Kuwait
Thanks guys.
More than enough for the winches I'm looking at Thumbs Up Solved the bowel problem, working on the consonants...
Post #565947 22nd Sep 2016 10:06pm
miker
You know you want a second battery regardless, dont you Laughing
Post #565949 22nd Sep 2016 10:07pm
agentmulder
Kuwait
On the list...
$ Big Cry $ Solved the bowel problem, working on the consonants...
Post #565952 22nd Sep 2016 10:13pm
