![]() | Home > Td5 > Worrying bursting noise |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Intercooler pipe/hose would be my first thought.
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
if it is the hoses, this should fix it
Click image to enlarge |
| megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358
What engine is that? the TDCi
The one my 110 is a TD5 He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
ah, td5 stainless intercooler pipes are available, in the UK and much more reasonable price .. can't remember who sells them but there's a thread somewhere on here ...
I have just been outside and popped the top off the engine and had a look at the hoses, unfortunately I cannot see anything suspicious
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
Well, a pop followed by a whoosh can only be a fairly high-volume pressurised thing failing and depressurising, which narrows it down to tyres (you'd have noticed), charge air circuit (intercooler or related pipework), or cooling system (you'd probably have noticed). I can't really see what else it could be, unless you ran over a plastic bottle.
The intercooler pipes are a well-known problem on the TDCi (hence the comments above) and often you can have a pipe which superficially looks fine but has a split which opens up under pressure, resulting in poor performance and a hissing or farting noise. If the intercooler itself had ruptured I would not expect the performance ever to improve, whereare if you have a hose/pipe malfunction it may be that it is OK up to a certain boost pressure, when it releases rather like a safety valve. I would be inclined to "fondle" the hoses to feel for soft spots and other defects which are not visible to the naked eye or are in areas you can't see before ruling them out. Last edited by blackwolf on 15th Sep 2016 3:59pm. Edited 1 time in total |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Blackwolf - that is exactly what happened to me. MR LR Assistance man could not find any leak etc until we 'fondled' each pipe and then found a split that only opened under quite a bit pressure. Superglue and gaffer tape got me home.
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
Did you run over a football?
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| 4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987
Just a thought... Is your AC still working? Maybe it blew its load? Pow woooosh! 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Yeah, AC fine.
There was nothing on the road. Its one of those annoying noises that at an Landy driver you lock ont as something that should not be there. What does worry me is the poor high speed performance last night when it failed to pull 70 uphill. I had just started getting used to all the new power, it was almost as perky as the wifes TDCi. I'm going to keep monitoring it on my regular hills, lets see how it goes up Ivinghoe Beacon tonight He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
I once had a HUGE bang from the rear, was googling stuff like 'can diesels backfire' and similar, spent ages looking under the vehicle and engine.
Most likely in my mind now, is that kids were throwing stones from a bridge i was passing under, nice ding in the roof found months later. Doesn't explain your hiss though... Solved the bowel problem, working on the consonants... Last edited by agentmulder on 15th Sep 2016 8:31pm. Edited 1 time in total |
No LOL
And to add hope, the TD5 drove beautifuly this evening ! Problem is after 25 years of Land Rovers strange noises make me paranoid ! He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
