Home > Td5 > Worrying bursting noise
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Yesterday I was cruising to work, I had done 14miles up the A41 at 60mph then was wandering through country lanes to the office, on a nice long straight I gently got up to 50mph when there was a lod pop and a hissing which dissipated after around 30 seconds!
I initially thought a tyre, being a 110 SW I run 48psi in the rears as specified. But there was no tack-tack-tacking from any object and all tyres and pressures appear fine.
However coming home downhill on the A41 the motor was struggling with foot to the floor to make 70mph and falling back on uphills. I will add that it was the hottest day of the year !
Last month I had the EGR deleted and a remap. The 110 has been driving superbly since then, cruising at 70 with plenty of oomph.
This morning on the drive to work all feels well though I used another route and it is pulling well.
I cant see anything visibly but have not had the opportunity for a good look under the bonnet.
I am wondering if the higher boost pressures and temps of the remap may have cracked an intercooler end cap
Any ideas people? He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #564095 15th Sep 2016 9:48am
Intercooler pipe/hose would be my first thought.
Post #564116 15th Sep 2016 11:42am
if it is the hoses, this should fix it
Post #564128 15th Sep 2016 12:24pm
megatoad
What engine is that? the TDCi
The one my 110 is a TD5 He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #564142 15th Sep 2016 12:55pm
ah, td5 stainless intercooler pipes are available, in the UK and much more reasonable price .. can't remember who sells them but there's a thread somewhere on here ...
Post #564144 15th Sep 2016 1:02pm
megatoad
I have just been outside and popped the top off the engine and had a look at the hoses, unfortunately I cannot see anything suspicious
LRSOC & CVLRC
Post #564160 15th Sep 2016 1:36pm
Well, a pop followed by a whoosh can only be a fairly high-volume pressurised thing failing and depressurising, which narrows it down to tyres (you'd have noticed), charge air circuit (intercooler or related pipework), or cooling system (you'd probably have noticed). I can't really see what else it could be, unless you ran over a plastic bottle.
The intercooler pipes are a well-known problem on the TDCi (hence the comments above) and often you can have a pipe which superficially looks fine but has a split which opens up under pressure, resulting in poor performance and a hissing or farting noise.
If the intercooler itself had ruptured I would not expect the performance ever to improve, whereare if you have a hose/pipe malfunction it may be that it is OK up to a certain boost pressure, when it releases rather like a safety valve.
I would be inclined to "fondle" the hoses to feel for soft spots and other defects which are not visible to the naked eye or are in areas you can't see before ruling them out.
Post #564165 15th Sep 2016 1:53pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Blackwolf - that is exactly what happened to me. MR LR Assistance man could not find any leak etc until we 'fondled' each pipe and then found a split that only opened under quite a bit pressure. Superglue and gaffer tape got me home.
Post #564175 15th Sep 2016 2:33pm
Martin
Site Admin
Did you run over a football? Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #564182 15th Sep 2016 3:07pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just a thought... Is your AC still working? Maybe it blew its load? Pow woooosh! 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #564184 15th Sep 2016 3:21pm
megatoad
Yeah, AC fine.
There was nothing on the road.
Its one of those annoying noises that at an Landy driver you lock ont as something that should not be there.
What does worry me is the poor high speed performance last night when it failed to pull 70 uphill. I had just started getting used to all the new power, it was almost as perky as the wifes TDCi.
I'm going to keep monitoring it on my regular hills, lets see how it goes up Ivinghoe Beacon tonight He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #564205 15th Sep 2016 4:54pm
agentmulder
Kuwait
I once had a HUGE bang from the rear, was googling stuff like 'can diesels backfire' and similar, spent ages looking under the vehicle and engine.
Most likely in my mind now, is that kids were throwing stones from a bridge i was passing under, nice ding in the roof found months later.
Doesn't explain your hiss though... Solved the bowel problem, working on the consonants...
Post #564273 15th Sep 2016 8:01pm
megatoad
No LOL
And to add hope, the TD5 drove beautifuly this evening !
Problem is after 25 years of Land Rovers strange noises make me paranoid ! He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #564286 15th Sep 2016 8:25pm
