Home > Td5 > Transfer Box - Ratio Change
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
So after a trip to the South of France last year and 2500 miles up to and around the highlands this year, I took the plunge and had the Disco ratio upgrade fitted.
Only driven about 100miles back from Ashcrofts yesterday but I am so far very pleased. Where it felt like she was revving a bit at about 63mph to keep out of the trucks way on the motorway, it'll now sit happily at 70 and keep up with the traffic with plenty to spare.
The cruise control obviously stopped working because of the lower revs but fitted a Speedo Healer last night and all now seems to work like a dream. So far, so good! 2002 Defender 110 CSW TD5
Post #564104 15th Sep 2016 10:51am
DunningBoy
Sounds great. I'm thinking about this for mine so interested in hearing any info on how they are.
Post #564132 15th Sep 2016 12:35pm
Steve, I did the same on my td5, so much quieter too Thumbs Up
Post #564145 15th Sep 2016 1:03pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
A very worthwhile modification, i fitted a box from a disco 1 to my my 300 tdi 110 when i had it about 10-11 years ago, much better for long journeys, i fitted it before going a trip around the western isles. one of the best land rovers i have had. nobody is perfect but being Scottish is a start
Post #564158 15th Sep 2016 1:28pm
Martin
Site Admin
Which speedo healer did you use?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #564163 15th Sep 2016 1:49pm
Dial222
United Kingdom 1994 Defender 110 300 Tdi ST Nato Green
I'm thinking of putting a 1.22 Disco Transfer box into my 300 1.66 ratio'd ex mil 110.
Do i need to adjust speedo in some way? 2016 110 XS CSW
2013 110 XS CSW
2008 Disco 3 (Current)
2006 110 XS CSW
2001 Disco 2
1998 90 CSW
1996 Disco 1
1994 110 TUM (Current)
1993 110 Snatch 2A (Current)
1992 90 CSW
Half a dozen Discos and a RR Classic
Post #564226 15th Sep 2016 5:48pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Re: Transfer Box - Ratio Change
I had mine done just before we went on our holiday this year. I also had a cheeky remap from Mike at Dynachip to restore the acceleration. It's so much better now and at last I have done something to the car that the other half approves of. Shocked
I was also considering fitting cruise control but wondered if the mod would cock it up, which you confirmed it did, but have found a way round it Bow down Did you use a kit for the cruise control or the list of parts and method that's written about on this site Somewhere?
Post #564238 15th Sep 2016 6:46pm
steve_c3
Martin, I used the Speedo HealerV4 from Heal Tech. Got it from Ashcroft at the same time. Nice and easy to wire in too.
Dial222, no need to adjust the speedo on a TD5 as I believe it takes its feed from somewhere other than the T-Box. Not sure about the 300tdi though I'm afraid...I'm sure someone else may know more!
A short run to and from work today and still chuffed with it. It just needs a different driving style. I had an Alive remap last year so been quite use to having short gear changes and keeping the revs low and letting the torque pull you around. Usually into 5th at about 25mph upwards. Now it needs 4th at anything below 30.
Findings so far:
1st needs a few more revs to take off but nothing terrible and not slipping the clutch so no worries there.
2nd is longer and needs to rev a bit more to make sure it doesn't bog down too much into third.
3rd with the old ratios used to be very quick and a lot of fun! But was often the source of lower mpg figures when you were a bit heavy with the right foot. It's now more Defender-like but still plenty of pull.
4th fine for 30 limits and hills.
5th Good for anything over this but not sure how it's going to fair with the CC and hills on the motorway. I wonder if the turbo will be spinning enough for the CC to do its job and pull you up unless I'm doing 70.
Guess I'll find out on the way up to Peterborough at 7am on Saturday!
I wonder if Alive may need to do some fettling with the map to account for the new box? 2002 Defender 110 CSW TD5
Post #564279 15th Sep 2016 8:13pm
steve_c3
I used info gained from this site and a couple of others. Some basic wiring and a Disco switch. I just made sure to check and triple check I was cutting and connecting the correct ECU wires!!! There's some pics of mine here...
http://www.defender2.net/forum/topic42575.html 2002 Defender 110 CSW TD5
Post #564290 15th Sep 2016 8:32pm
jonny2tanx
Thanks for the reply. That's something that would have helped greatly on our trip - ws did just shy of 4000 miles
Post #564367 15th Sep 2016 10:56pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
mines on a 1.2 and it's great as it spends most of its life on the motorway. I'm also geared up on 33" tyres so 70 is nice and quiet.
Only downside is everyone in a blue moon I struggle with hills with the caravan and have to make sure I hit them with the turbo boosting. I also tow cars occasionally for my best mates garage. but it copes with that fine. 2nd gear starts are no problem
I don't have a remap as the insurance won't let me 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #564496 16th Sep 2016 2:29pm
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
Hello, could you guys tell me what tyre size you are running with your 1.2 transfer boxes?
Post #564600 17th Sep 2016 9:57am
excossack
With my 110 I am on 235/85 R16 BFG AT. Mild stage 1 map 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #564601 17th Sep 2016 10:22am
steve_c3
^^^ Same set up as this. 2002 Defender 110 CSW TD5
Post #564642 17th Sep 2016 4:45pm
gazman
33 x12.5x15 2014 - current ..... 2003 defender td5 90 (my car)
Post #564730 17th Sep 2016 9:52pm
