![]() | Home > Maintenance & Modifications > Rear Spring Replacement |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Update - see http://www.defender2.net/forum/topic49065.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
| brooksa Member Since: 17 Apr 2018 Location: Virginia Posts: 3
very helpful, thanks!
| pawsinmud Member Since: 08 May 2016 Location: Hampshire Posts: 3
This was really interesting thanks. My 90 is way too stiff at the rear and softening the springs seems like a good way forward.
| Kizmax Member Since: 17 Dec 2020 Location: Clare Posts: 10
Excellent write up and refresher for me as I’m about to do my 130 which has double springs
Cheers |
| orzowei Member Since: 10 Mar 2021 Location: toscana Posts: 14
[quote="bm52"]Hi,
Mine is now set up for the 90 4 seat station wagon (2400 Kg) as shown below. I used Koni Heavy Track not the Raid which are very heavy duty and costly hello Guys, on my 2008 puma 90 I mount the following springs. 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red / green / white Front - Passenger side REB500220 Red / green / orange Rear - Driver's side RKB500270 White / green / pink Rear - Passenger side RKB101240 Green / yellow / white Are they USW or CSW springs? in your opinion .. if I mount the Kony Ht (not the raids) I get a more comfortable ride? when I load the defender a lot, when cornering it tends to lean a lot, and I think my springs are tired (150k) thanks .. and sorry for my English! Giulio from Tuscany, Italy. --------------------------------------------------------------------------------- ciao Ragazzi , sulla mia 90 puma del 2008 monto le seguenti molle. 90 4 seat station wagon (2550 Kg) Front - Driver's side REB500200 Red/green/white Front - Passenger side REB500220 Red/green/orange Rear - Driver's side RKB500270 White/green/pink Rear - Passenger side RKB101240 Green/yellow/white Sono USW o CSW? secondo voi.. se monto i Kony Ht ( non i raid) ottengo una guida piu confortevole? grazie.. e scusatemi per linglese! GIulio from italy |
