Home > Puma (Tdci) > 2008 tdci 90 new puma
dorsetsmith
i m looking at 90 pick-up 2008 on instilment panel then in low rang any should they be any light in dash 2008 model ?
Post #364002 12th Oct 2014 8:38pm
Dieselhead
Dont understand this??????????????????????????? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #364473 14th Oct 2014 7:43pm
dorsetsmith
i have looking at 2008 2.4 pick-up county from roger young went fro test drive put transfer low range no light in dash ?
and no diff lock light Question have look at my 2012 low range light ilmenite than low range is selected
Post #364481 14th Oct 2014 7:59pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
There is no lamp in the cluster that illuminates when low range is selected.
There is a low range symbol on the fascia, I assume this does activate in the Discovery. http://defender90xs.blogspot.co.uk/
Post #364482 14th Oct 2014 8:01pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
There should be a light for when diff lock is engaged. If I remember correctly it is on the right hand side of the instrument cluster. 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #364483 14th Oct 2014 8:07pm
dorsetsmith
light for when diff lock engaged not working ether number 14 post work shop PDI and oil leak from front transfer box
my question is should the low rang light work
new to 2.4 tdic defenders
TD5 90 for 8 years
Post #364489 14th Oct 2014 8:19pm
Happyoldgit
No Steve.
http://forums.lr4x4.com
Post #364492 14th Oct 2014 8:34pm
Josh K
As far as I'm aware, there is no low range light in 2.4 models. A search on the forum does come to this conclusion as well. Have a search for diff lock light and there are plenty of results of how to rectify this. 2007 (57) Defender 90 (Sold)
Post #364494 14th Oct 2014 8:34pm
Happyoldgit
Ok, to simplify what should be a simple question and answer:
No low range light when low range selected.
Difflock light will illuminate when centre difflock engaged. Steve.
Post #364497 14th Oct 2014 8:37pm
dorsetsmith
thank i stick TD5 at lest no how they work looking at 2006 black 90 pick up 38,000 in clock
Post #364498 14th Oct 2014 8:40pm
Happyoldgit
The light functions regarding difflock and high / low are the same. Steve.
Post #364567 15th Oct 2014 8:10am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
In a Puma the following numbers (as per diagram above) is not relevant and will never light up:
No 3, 20, 22, 23 and 27.
Post #364580 15th Oct 2014 8:59am
Benassi01
United Kingdom 2012 Defender 110 Puma 2.2 USW Stornoway Grey
No.22 Light.
Regard, you mention none of those numbered lights will ever come on, I've had no.22 come on for about 10 mins today and I'm trying to find out what it means!! lol.
Post #562005 6th Sep 2016 9:55pm
Benassi01
No.22 Light.
Post #562008 6th Sep 2016 9:56pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
That looks like a DPF warning lamp. An amber light illuminated would need a manual regeneration taken place I would have guessed. I don't have a 2.2 puma but this is the case on lorries.
Post #562015 6th Sep 2016 10:40pm
