![]() | Home > Puma (Tdci) > 2008 tdci 90 new puma |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Dont understand this??????????????????????????? Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
i have looking at 2008 2.4 pick-up county from roger young went fro test drive put transfer low range no light in dash ?
and no diff lock light ![]() |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
There is no lamp in the cluster that illuminates when low range is selected.
There is a low range symbol on the fascia, I assume this does activate in the Discovery. http://defender90xs.blogspot.co.uk/ |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 ![]() ![]() ![]() |
There should be a light for when diff lock is engaged. If I remember correctly it is on the right hand side of the instrument cluster. 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
![]() light for when diff lock engaged not working ether number 14 post work shop PDI and oil leak from front transfer box my question is should the low rang light work new to 2.4 tdic defenders TD5 90 for 8 years |
No Steve.
As far as I'm aware, there is no low range light in 2.4 models. A search on the forum does come to this conclusion as well. Have a search for diff lock light and there are plenty of results of how to rectify this. 2007 (57) Defender 90 (Sold)
Ok, to simplify what should be a simple question and answer:
No low range light when low range selected. Difflock light will illuminate when centre difflock engaged. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
thank i stick TD5 at lest no how they work looking at 2006 black 90 pick up 38,000 in clock
The light functions regarding difflock and high / low are the same. Steve.
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
In a Puma the following numbers (as per diagram above) is not relevant and will never light up:
No 3, 20, 22, 23 and 27. |
Benassi01 Member Since: 06 Sep 2016 Location: Lutterworth Posts: 3 ![]() ![]() ![]() |
Regard, you mention none of those numbered lights will ever come on, I've had no.22 come on for about 10 mins today and I'm trying to find out what it means!! lol.
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
That looks like a DPF warning lamp. An amber light illuminated would need a manual regeneration taken place I would have guessed. I don't have a 2.2 puma but this is the case on lorries.
