![]() | Home > Maintenance & Modifications > Advice on 'lifting' the vehicle by 2" |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6030 ![]() ![]() |
Talk to Gwyn Lewis,
![]() ![]() ![]() http://www.gwynlewis4x4.co.uk/ He will tell you all need to know. He also does a very nice kit that raises by 1" but has extra travel that my mate has fitted to his Tdci. He will also tell you that EVERY Landy is different. Andy |
Yep, Gwyn is the man. He does heavy duty corrective arms, v impressive.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
I fitted a 2" lift to my 100" bitsa a few years ago via the yellow springs and pro comp shocks route, it was horrible, ride and handling were pants. Tried other springs still no use, went back to std springs with 50mm spacers and new std ride height shocks plus 3 degree QT arms and it was back to superb, steering self centred again and ride and handling were great.
Next biggest improvement was detroit locker in the back and a true trac in the front - REAL SELF CENTERING STEERING! |
I've been up to his before very very helpful guy...only 30 mins away as well
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Not with OME 754's and a set of these baby's ![]() ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I went for Tarantular arms on my Discovery.... They have some Angle Iron welded to the under side to protect them from rocks (how I bent the origionals in the first place).
I will be going full Gwyn Lewis kit on the Defender though ![]() ![]() *Cough* Group Buy *Cough* Glyn ![]() ![]() Last edited by Glynparry25 on 1st Feb 2011 10:28pm. Edited 2 times in total |
I've got Bilstein HD Shocks and discovery extra HD Springs all round and its 100 times better than the standard
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Yes we had extended shocks fitted at that time ![]() Brendan |
![]() Andrew, yep those are pretty cool I must say. I would say that, since I fitted some today, at Glyns ![]() Well, I say fitted. I was the hamfisted, meatheaded spanner ![]() |
I was also informed that 'bushing' is just a 'sticking plaster' solution, radius arms at about �100 ballpark each is the way to go! Decisions decisions!!! I have OEM set up at the moment and to do it correctly would be about �700 all in! May 'can it' as it is a desirable not a necessity! Never know may win the lottery or premium bonds!
![]() Treat every day as if it is your last....one day you will be right!! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
you can get axle spacers, might be an option for you 2" is quite a lot, i'm going 1-1.5" up and +5 down! is all in the droop off road
Glyn Lewis is booked in at the 4x4 travel show on 13th Feb, so if you want to see his wares/speak to him it might be worth a visit!
Brendan |
Just don't call him Glyn
sasha2001 Member Since: 02 Jan 2009 Location: New Zealand+ russia Posts: 206 ![]() ![]() ![]() |
have a look here guys
From Ozzie forum http://www.aulro.com/afvb/90-110-130-defen...ouble.html |
