Home > Maintenance & Modifications > Advice on 'lifting' the vehicle by 2"
Page 1 of 4 1234>
K9F
I am considering 'lifting' my vehicle by a couple of inches! I am also aware that there are several options available to achieve this! I have heavy duty suspension as standard and would not look at spring and shock replacements! The advice I seek is thus....Is it fact or fiction that lifting the vehicle would throw the castor out by 3 degrees and therefore the springs would be slightly out of alignment and increase strain on the propshaft?? Also to counteract the 3 degree castor it is advisable to replace or bush your radial arms to counteract this??
Any advice gratefully received!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #56092 1st Feb 2011 9:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
simon from devon 4x4 would sugest you dont need any sort of castor correction on a 2 inch lift ?
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #56095 1st Feb 2011 9:36pm
BigMike
K9, what's the reason for the lift? If you already have HD springs etc what will it achieve? in terms of degrees it wont neccessarily be 3 degrees, it ll depend on how you lift it using what components. Are your HD springs OEM or aftermarket? if the latter, you may find already that you have a lift. It's easy to tell, just measure from the top to the bottom of the spring. Standard (on a unladen 90 anyway) when on the vehicle itself are 300mm. If yours are any longer that's the amount of your lift. Not sure what they are on a 110
and yes, you will need correction arms.
No idea where Simon from Devon 4x4 is coming from with that steve, there is a marked difference in the arms, you can just kneel down and see the change in angle and its effect on the bushes. Plus, 2" on the front and you'll probably need a double cardon prop, depends on if you feel vibration of not but at 2", its likely.
ETA - your radius arms might need doing as well. It's a lot of money really just to lift your truck a bit unless there is a good reason (a good reason to you of course)
Post #56101 1st Feb 2011 9:43pm
K9F
Thanks Steve, seem to be following each other through the threads! I've heard different things from different people! Good handling at higher speeds are important to me and if need be I am prepared to wait and spend the extra couple of hundred quid to get it done right! A mucker of mine implied handling would be affected without castor correction??? Wonder what everyone else has done or their own experiences all advice welcome! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #56102 1st Feb 2011 9:44pm
Glynparry25
Re: Advice on 'lifting' the vehicle by 2"
K9F wrote:
The advice I seek is thus....Is it fact or fiction that lifting the vehicle would throw the castor out by 3 degrees and therefore the springs would be slightly out of alignment and increase strain on the propshaft?? :
FACT... I lifted my Discovery by 2". A few months later I swaped steering to Sumo bars and when having them set up (Alignment) the garage adjusted everything but mentioned that the castor was out by 3 degrees.
Do you need new props, castor corrector arms/ bushes...... That is an uncertainty. I know people who have put 3" lifts on without any problems, other have put a 2" lift on and had steering problems, and prop problems which were rectified by castor corrector arms.
Only way to know will be to fit the kit and see how it goes, then fit other parts as necesary
Glyn Dog Sheep
Post #56105 1st Feb 2011 9:46pm
BigMike
and handling will most certainly suffer at high road speeds.
Post #56106 1st Feb 2011 9:47pm
Glynparry25
I think this will all be down to which springs and shocks.
Again on my Discovery (as above) the ride was soft and unstable on the standard springs and shocks. The HD springs and firmer shocks made the Disco WAY more stable at all speeds..... My dad is also looking at kits after driving mine!
Glyn Dog Sheep
Post #56108 1st Feb 2011 9:52pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
3" and no problems Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #56109 1st Feb 2011 9:53pm
BigMike
True. I guess it depends on which shocks/springs set up K9 has at the moment
Post #56110 1st Feb 2011 9:53pm
leeds
Red 110 was lifted 2" with 255/85 tyres. Brake hoses were extended. No castor correction done.
After about 25,000 miles due to driver error a new chassis was required. Castor correction arms were fitted at that stage. Was a drop in the ocean compared to rest of work being done Razz Laughing
No handling difference were experienced after the lift, no improvement was noticed with correction ars fitted.
I wold say that conventional wisdom is up to a 2" lift extend brake hoses and only go down castor correction arms if problems experienced
3-4" lift then go for castor correction from the off
HTH
Brendan
Post #56111 1st Feb 2011 9:54pm
BigMike
fekete wrote:
3" and know problems Thumbs Up
that you know of yet Laughing Thumbs Up
Post #56112 1st Feb 2011 9:54pm
Glynparry25
Just a little pick at that.... I know loads of people who have been conned by that statement.
Only need extended brake lines if you fit extended shocks.... lots of 'suspension kits' come with standard (or slightly extended) shocks which means you don't need extended lines.
Glyn Dog Sheep
Post #56114 1st Feb 2011 9:58pm
BigMike
What Glyn said. You dont need extended hoses with standard travel shocks and a 2" lift.
Post #56116 1st Feb 2011 9:59pm
fekete
Yep Glyn you correct you don't need extended lines....
Mike not even a bit of vibration Thumbs Up YET NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #56119 1st Feb 2011 10:04pm
BigMike
Karl, take a look at the angle of the trailing arms where they meet the chassis, and look at the gap where the bush sits. There will be one. Everytime you go over a bump the front section of the arm is being jarred and eventually is likely to snap, esp during v cold weather
Post #56120 1st Feb 2011 10:08pm
Page 1 of 4 1234>
