Home > Maintenance & Modifications > installing heated seats
countdecash
Ireland 1999 Defender 90 Td5 CSW Epsom Green
Just about to install heated corbeau seats in my td5..........couple of questions....wheres the best/easiest place to take power from and where is the best /easiest place to locate switches for same? Cubby? Drill dash somewhere?
Post #560807 2nd Sep 2016 2:00pm
RRUK
I put genuine switches into the dash centre panel where the blanks were, wiring ran along the gbox tunnel and up to the main fuse board to a spare fuse, then up behind the dash to the switches. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #560818 2nd Sep 2016 3:05pm
Martin
Site Admin
No blanks for heated seats on a 1999 Td5
countdecash are you using genuine or aftermarket switches?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #560819 2nd Sep 2016 3:14pm
countdecash
bought all from lri solutions so it's the two stage switch they use
Post #560832 2nd Sep 2016 4:20pm
Martin
Site Admin
OK so the round Waeco switch.. perhaps in the centre panel under the radio (I've put my genuine switches there)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #560839 2nd Sep 2016 4:40pm
countdecash
do you mean the little panel that screws out where the rear wipe and cigarette switches are?
Post #560841 2nd Sep 2016 4:51pm
Martin
Site Admin
Yep Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #560846 2nd Sep 2016 4:57pm
If you want you don't need the two stage switch, it's only a pre-head function and normal function selection.
I run mine on normal all the time and switched that way, never seen the purpose to the pre heat as they are more than warm enough on normal!
So much so, they are warmer on the normal heat than what many manufactures seats are as standard.
Really nice in weather when you need it. Thumbs Up
Have a look at FCX's kit for wiring if you want to go don't the OE look route and it's all there for you.
Mines a Puma kit so I'm not quite sure if there is one for a TD5 and how similar or dissimilar it would be.
You can get genuine plugs and sockets too for a real genuine finish if you liked.
Post #560850 2nd Sep 2016 5:19pm
countdecash
ok will do though i think these come fully wired............looking forward to a bit of comfort this winter!
Post #560857 2nd Sep 2016 5:41pm
Martin
Site Admin
Good points Steve but as there is no place for factory switches in a pre-2002MY Td5 then a genuine switch would need custom mounts. Fitting the twin stage switch may be a lot easier (and could be upgraded from in the future)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #560927 2nd Sep 2016 9:35pm
Thumbs Up
Post #560930 2nd Sep 2016 9:47pm
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
If this is any help, I too have installed heated seats in my 2004 td5, seeing that the proper switches cost a fortune everywhere I looked I just tried discovery heated seat switch search and sure enough the disco has the right switch and seat logo being the right way up. I got 2 off eBay for £26, the switches are black but it is hard to notice the difference.
Post #561660 5th Sep 2016 6:59pm
AMBxx
I put heated seats in a '97 Td5. I put the switched on the front of the cubby box. That way, the wiring could be run under the cubby to the seats. Kept everything simple.
Post #561783 6th Sep 2016 8:12am
