![]() | Home > Puma (Tdci) > Rattle in my ear |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 ![]() ![]() |
I have a rattle on a 2013 TDCi in my right ear. I think it's the door post and have removed and refitted trim and seat belt as well as secured wiring with silicon. None of that worked and now my wife is complaining of the same on her side. Any thoughts?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Make sure you have no load in the rear or something positioned somewhere that could rattle too.
Many a time it's been known for someone to think something is wrong when in fact it's an item stored somewhere. You have probably checked but worth mentioning. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
On mine it was the plastic covering the door striker, which had worn to bare metal, rotating it so the hole was facing 180deg the other way solved the issue
![]() Eventually when the newly exposed face wore itself, I swapped the front ones out with the rear units, and then finally got new ones. Bearmach were ![]() |
^ Better still replace with X-eng strikers, they have a metal part in stead of that plastic thingy. Will not wear out and doesn't eat trousers...
![]() ![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
There is a flimsy strengthening plate above the seat belt spool - check that and it may require bonding to the body. I think this is flexing when the body twists which sounds like a rattle. Took me ages to locate but rattles no more
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
x2 for this. the bolts along the roof line can come lose, but the ones on the B post often require a little tightening. Im assuming its a metallic noise if not the plastic trim can also come lose. good luck |
