Home > Puma (Tdci) > Rattle in my ear
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
Rattle in my ear
I have a rattle on a 2013 TDCi in my right ear. I think it's the door post and have removed and refitted trim and seat belt as well as secured wiring with silicon. None of that worked and now my wife is complaining of the same on her side. Any thoughts?
Post #560770 2nd Sep 2016 11:56am
On my DC I had a similar rattle and found that the bolt holding the top of the "B"-post to the roof was loose on both sides. The factory, it would seem, had simply not bothere to tighten them up!
You can get a similar rattle from the doors if the shut needs adjusting, so before stripping out the headlining to check the "B"-post bolts you might want to try winding the window down 6 inches and pulling the top of the door hard inwards to see if that stops the rattle. if it does, adjust the striker plate on the "B"-post (and if necessary the hinges) to get a proper shut.
Post #560774 2nd Sep 2016 12:07pm
Make sure you have no load in the rear or something positioned somewhere that could rattle too.
Many a time it's been known for someone to think something is wrong when in fact it's an item stored somewhere.
You have probably checked but worth mentioning.
Post #560776 2nd Sep 2016 12:17pm
agentmulder
Kuwait
On mine it was the plastic covering the door striker, which had worn to bare metal, rotating it so the hole was facing 180deg the other way solved the issue Smile
Eventually when the newly exposed face wore itself, I swapped the front ones out with the rear units, and then finally got new ones. Bearmach were Censored , had to go genuine. Solved the bowel problem, working on the consonants...
Post #560876 2nd Sep 2016 7:22pm
VeeTee
Netherlands
^ Better still replace with X-eng strikers, they have a metal part in stead of that plastic thingy. Will not wear out and doesn't eat trousers... Laughing Thumbs Up
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #560884 2nd Sep 2016 8:04pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
There is a flimsy strengthening plate above the seat belt spool - check that and it may require bonding to the body. I think this is flexing when the body twists which sounds like a rattle. Took me ages to locate but rattles no more Thumbs Up
Post #561005 3rd Sep 2016 10:34am
nidge n
x2 for this. the bolts along the roof line can come lose, but the ones on the B post often require a little tightening. Im assuming its a metallic noise if not the plastic trim can also come lose. good luck
Post #564034 15th Sep 2016 1:40am
