Home > Maintenance & Modifications > Greasing
Cheshire110
Greasing
So on my 2016 110, what should I be greasing?
I'm trying to be well set up to protect and look after it into the future! Cheers, David
Post #558782 25th Aug 2016 8:49am
dorsetsmith
prop shaft UJ
Post #558789 25th Aug 2016 9:11am
Cheshire110
Yep that was the one I kinda knew - not looked on the recent ones, are they fitted with a nipple? Cheers, David
Post #558790 25th Aug 2016 9:17am
Cheshire110
**duplicate** Cheers, David
Post #559003 25th Aug 2016 11:41pm
agentmulder
Kuwait
Check the drive flanges are lubed with respect to the halfshafts, they wont be out of the factory, but IMO after seeing the red powder accumulate from fretting then corrosion it's a good thing.
By rights you should replace the gasket when you do this, not too much drama Smile
Easy with steels! Solved the bowel problem, working on the consonants...
Post #559017 26th Aug 2016 4:50am
Alien
Australia
Mine has no grease nipples in any of the steering gear which surprised me.
All my universals have nipples fitted(MY12).
The drive flanges as mentioned, mine where dry when I got it with 3 years of use.
Long term maintenance when you want to go pulling things apart as time/millage gets on...
Wheel bearings.
Swivel hubs/CV's.
With great risk of opening a can of worms...
Although not listed by LR for maintenance don't forget the dreaded adaptor shaft. Cheers,
Kyle.
Post #559019 26th Aug 2016 5:58am
Cupboard
Easy with steels!
How do you grease them? What do you do once you've remove the dust cap?
Post #559084 26th Aug 2016 1:05pm
Fatboy Slim
Wales
Weld the back ones up Whistle and lube the fronts with some ep90
Post #559189 26th Aug 2016 8:31pm
agentmulder
Kuwait
Remove circlip. (If initial inspection shows a lot of corrosion it's probably a good idea to have some spares and/or just install new ones after, they're real cheap...)
Remove 5X flange bolts and pull off the flange, a tap with a hammer will assist in breaking the gasket connection to the hub (and if corroded breaking any 'rust-weld' between it and the halfshaft). Easier to do than explain Thumbs Up
If the halfshalft comes out on the rear, no fuss, good opportunity to check the internal splines also...
Clean up the flange and hub from gasket residue (use a gasket scraper or something expensive from the kitchen), clean up flange and outer shaft splines and inspect backlash/meshing. Replace if required (and your wallet permits). Use OEM and/or bearmach or better, definitely not britpart pattern.
Otherwise grease up splines. Easy! I used heaps (to allow for the wiping action of the reinsertion)
Insert shaft into axle, fiddle until it seats properly into the diff, oh and try to be careful not to force the internal seal out of the stub axle if you get resistance after the first 200mm or so.
Clean flange bolts or install new, return flange and new flange gasket, torque up to WSM spec (and loctite if specced).
Circlip, grease packed dust cover, wheels.
Drive to shop to get some biccies.
(I'll look up torque specs layer, phone currently on %3 battery!) Solved the bowel problem, working on the consonants...
Post #559235 26th Aug 2016 10:14pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Just reading posts on drive flanges and have been looking at potentially changing mine eventually, however as the vehicle is pretty new I thought I would just whip off the drive flanges and lubricate the splines first. I know folks have used grease but I quite like Rocol anti scuffing paste and wondered if anyone has used this in preference to grease to lubricate the splines?
Post #608190 9th Mar 2017 7:39pm
